can you degree cams with the motor in the car?
Old Dec 2, 2009 | 08:30 PM
ericrx_88's Avatar
Default can you degree cams with the motor in the car?
Hey just upgraded cams to sks 2 pro 2. I never Degreed cams before wondering if I would have to pull the motor to do it?
Old Dec 2, 2009 | 08:47 PM
95skunkedgsr's Avatar
Default Re: can you degree cams with the motor in the car?
no but it would make it alot easyer do u have the mike belben kit
Old Dec 2, 2009 | 08:58 PM
ericrx_88's Avatar
I haven't bough a kit yet would that be the one to get
Old Dec 2, 2009 | 09:45 PM
its honestly the only one i know of lol i dont think there is others but search it up and you should see the seller and there is acouple threads on how to do this , are you taking the car to the dyno to tune cam timing ? and has your head been mild or do your use a thinner head gasket ?
Old Dec 3, 2009 | 05:47 AM
ericrx_88's Avatar
Had scheduled a dyno tune for next Friday. Really didn't feel too comfortable with trying to mess with the cam gears. As I'm sure the head and blocks been milled and becked before. the block is a gsr bored 85mm gsr stroke cp pistons eagle rods. Bout 13.1 cr rlz pnp type r head with stock vavles with there springs sks pro 2 cams. Don't think ill get s kit in before then but if it possible to degree came in car I will just do that later
Old Dec 3, 2009 | 06:17 AM
92TypeR's Avatar
FSAE
You can use Skunk2 centerlines, reference them to OEM centerlines (0,0) and do the math.
Quick settings for B-series Pro2's are -1 intake / +3 exhaust. Add ~1 degree for every 0.015-0.020" off the deck height.
You will have no problems with P2V and V2V with those settings. Knowing your clearances will assist you when it comes to tuning cam timing.
Old Dec 3, 2009 | 06:50 PM
HdeucedeuceA's Avatar
^Where do you get the Skunk2 centerlines from? Just curious as to how the H22 Pro 1's would be set.
Old Dec 4, 2009 | 06:38 AM
92TypeR's Avatar
FSAE
Skunk2 has their cam cards on their website.
For example, H22 Pro1:
http://www.skunk2.com/installation/305-05-5200.pdf
Old Dec 4, 2009 | 07:12 AM
96Spec Ek's Avatar
What he said as a starting point.
Old Dec 4, 2009 | 07:39 PM
So how would I go about compairing them to OEM H22 cams? Sorry for the ignorant questins but this is competely new to me. I would imagine finding the OEM specs would be a good starting place, but what after that?
Old Dec 5, 2009 | 07:37 AM
onefstek's Avatar
You should be able to degree your cams with the motor in the car. But remember you have to do it on the vtec lobe so you will have to lock it in vtec.
It will not be easy to read the degree wheel, but you can do it.
Stefan
Old Jan 19, 2010 | 08:57 PM
egycasper16's Avatar
can you show how to lock the vtec by a picture
Old Jun 21, 2010 | 09:33 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
use a magnet to pull the rocker pin, drop a BB in there and put it back in
then stack em and reinstall
Old Jun 22, 2010 | 11:11 AM
teg_racer's Avatar
i just did this yesterday. since its hard to put them back in without loosing the bb zip tie them together install back in the head. get back on the rod and your locked. but only on one valve
Old Jun 22, 2010 | 07:20 PM
Justin Jones's Avatar
Mike Belben is back on HT? That just made my day.
Old Jun 22, 2010 | 07:55 PM
eg6madness's Avatar
Not to post hog or intrufe but does anyone know where to adjust the Rocket M24xx cams. Or where is a good starting point?
The specs I got are:
Vtec intake events at 0.050"
262 dur 102 lc open 28 btdc close 53 abdc
Max lift 0472"
Vtec exhaust events at 0.050"
262 dur 110 lc open 61 bbdc close 21 atdc
Max lift 0472"
Lobe centers 102 intake 110 exhaust.
What is the difference compared to stock ?
kimbler99
Dec 25, 2013 06:53 PM
ej_b16a
21
Aug 6, 2010 08:26 PM
darrinbrewer
May 12, 2006 05:46 PM
blowme
15
May 13, 2005 01:31 PM
98civicEX
Jun 28, 2002 06:55 PM
