head gasket for gsr???
Old Dec 2, 2009 | 06:56 PM
jesse0880's Avatar
Default head gasket for gsr???
I'm changing the head gasket on my gsr and I was wondering what the best and cheap gasket is out there? It's not for a race motor, just a daily driver.
Old Dec 2, 2009 | 07:30 PM
njmad's Avatar
Default Re: head gasket for gsr???
an oem gasket (a gasket from the honda dealer) will be the best for just daily driving
Old Dec 2, 2009 | 08:03 PM
SoTexDC2's Avatar
OEM, Honda/Acura.
I would never use anything else, unless the bore size needed isn't available, or there was a sealing issue.
Old Dec 2, 2009 | 08:07 PM
EL Vap133's Avatar
Just go with the OEM from the stealership, you do not want to use crap for a part like that.
Old Dec 2, 2009 | 10:07 PM
ILS_09's Avatar
+1. Go OEM.
Old Dec 2, 2009 | 11:32 PM
racebum's Avatar
OEM and felpro are the same gasket. buy whatever is cheaper. for the gsr headgasket app in north america fel pro is the honda supplier. don't worry, they are all made to honda spec. it's also obvious if you put them right next to each other.
check your block deck for trueness ! these gaskets almost NEVER fail in a stock app. blown headgaskets often mean warped blocks or warped heads.
Old Dec 3, 2009 | 07:29 AM
jesse0880's Avatar
awesome. thanks guys.
Eghatchgsr8
Sep 19, 2014 02:24 PM
chasmataz
Jul 25, 2010 08:35 AM
gowyeng
Feb 9, 2005 06:36 AM
808b18c1boosted
Dec 22, 2003 01:11 PM
Hayasa15
Jun 7, 2002 01:17 PM
