crx b16a codes
hey anyone help me out here i have a video of the codes im throwing can u please tell me what they are heres a video.. crx with a b16a obd0
http://s276.photobucket.com/albums/k...91202-1423.flv
looks like its throwing a code 5,6,7, and 14
5- map sensor
6- water temp. sensor
7- throttle position sensor
14- idle air control valve
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/all-ecu-codes-you-will-ever-need-1710584/
try searching
first thing you need to do is replace the coolant temp. sensor. its like a $9 part at autozone. usually when the coolant temp. sensor goes bad it will throw off other codes like TPS i know for sure. replace the coolant temp. sensor and go from there.
5- map sensor
try searching
joestud
Sep 14, 2013 01:58 PM
RB_EJ8
Jul 17, 2008 05:05 PM
