starting issues
Old Dec 2, 2009 | 10:36 AM
west nile's Avatar
Default starting issues
so anyone experience this?
turn the key and engine turns over and immediately shuts off. Does this 2-3 times then finally stays on. Been doing this consistently for the past week usually only when the engine is cold. Battery and alternator is cool. Plugs/wires/oil is cool.
I get code 16 during vtec so i was going to replace the injectors, but now this is starting to sound like an ecu issue also what i thought might throw code 16 since main relay is cool.
any ideas?
Old Dec 2, 2009 | 10:59 AM
CrxChicken's Avatar
Default Re: starting issues
My manual only shows code 15 and 17
but it says if it is cutting out and check engine is on and self diagnostics light is on and ecu is sending code 15 then it is on the Backup Unit for the ECU and you should swap out the ECU to test...
could be a main relay
you might have enough fuel line pressure to get the car started then it cuts out
If you need one you can get them online just check the part # ... less then Honda and same part.
Old Dec 2, 2009 | 11:21 AM
BiG ChOr!Zo's Avatar
you have a bad starter ignition switch...!!!
raymondpowens
May 10, 2015 09:06 PM
jchrm80
Dec 20, 2007 12:41 PM
kinaiahi
Jul 29, 2005 05:58 AM
allm0torGSR
Apr 30, 2004 05:10 PM
charjacq
Jun 29, 2002 08:13 PM
