about to buy ef sedan
Old Dec 2, 2009 | 08:42 AM
blade*13's Avatar
Default about to buy ef sedan
hey guys im about to buy my first honda which is an 88 ef sedan. all it needs is piston rings and i heard you can change the rings without pullin the motor. is this true? any help would be great. thanks in advance.
Old Dec 2, 2009 | 09:26 AM
4g4dcruisin's Avatar
Default Re: about to buy ef sedan
this is true if you go in from underneath.
pull the oil pan, remove oil pump, removing piston connecting rods from the crank shaft.
im pretty sure you have to remove the crank shaft as well. but like i said you dont "need" to pull out the motor for this one, but you WILL have to remove the downpipe from the exhaust manifold.
Charlie Moua's Avatar
yes you can re-ring it...
that still requires a lot of work
removing oil pan rods, piston, head & calling around to see if shops in your area have the right honing tool to clean up the walls for the new piston rings.
If you don't have enough experiance, I would tell you to have a professional do it.
Old Dec 2, 2009 | 09:38 AM
ed4doorcivic's Avatar
how many miles does it have?
mine needs piston rings, wich I have bought but i have been calling machine shops and they are telling me that i will probably have to bore the block to .20" more and get the right size pistons, My car is smoking real bad so i got the rings for the stock d15b2 pistons but i might have to do ALOT more than I thought, but U should get it tested at the Machine Shop before u buy and RINGS!!! Just a heads up bro, I LOVE SEDANS!!!!
Old Dec 2, 2009 | 03:52 PM
blade*13's Avatar
thanks guys. ive built motors before. just new to the honda game. so i wasnt sure about it. i just found out the motor has no compression across the board so im starting to think it has a blown head gasket. what do you guys think?
Old Dec 2, 2009 | 04:17 PM
I call it blown head gasket, just rip the head off and re ring it and new gaskets all around!
Old Dec 2, 2009 | 04:48 PM
blade*13's Avatar
so if i deciede to re-ring it should i get the blocked honed out?
Old Dec 2, 2009 | 10:29 PM
4drEF's Avatar
Keyboard Humorist
If it's a blown head gasket then why re-ring?
Have you tried putting a cap of oil in the cylinders to see if you get compression up?
Or done anything like a leakdown test to see where you loosing compression?
Old Dec 3, 2009 | 03:55 AM
blade*13's Avatar
well considering i havent bought it yet or had the time to go to by to check the car out in depth. no i havent done any of that. but thanks for the reply. and i will do that once i get a chance.
kUrb3d
20
Dec 26, 2019 04:57 AM
Mickeys95
Apr 7, 2014 03:20 AM
Hondaruss
May 20, 2007 02:44 PM
sodacan33
Jun 10, 2004 07:10 AM
Westrock2000
Mar 30, 2002 04:31 PM
