car turns over slow and wont start
Old Dec 2, 2009 | 08:38 AM
jlfrnce's Avatar
Default car turns over slow and wont start
have a 2001 B18C1, i had burned a hole in my piston, got some new #3 rods with pistons, i put new rings and plasti-gauge the bearings all with-in specs, i turned the motor with a ratcher/socket prolly 10x or more, and when i went to fire it up, it turns over slow, seems like it wants to stop or hestitate to turn over, threw charger on battery over-night and still same issue. Any ideas?
Old Dec 2, 2009 | 09:32 AM
ILS_09's Avatar
Default Re: car turns over slow and wont start
how's your timing?
Old Dec 2, 2009 | 09:44 AM
jlfrnce's Avatar
i had put the cam marks together, and the pink dont on the crank pully is lined up with the mark on the oli pump, i did move the dist. and doesnt do any better either way i move it, took plugs out and turned lil faster, just no compression. plugs were wet, and no metal shavings or anythng else unwanted
Old Dec 2, 2009 | 11:54 AM
jlfrnce's Avatar
re-checked timing and that is on, i did plasti-auge and bearings were with-in specs, but did have 3-#2's and 1-#3, and now have all #3's in car(rods), just tried new plugs and tried to start first time key was turned, but then nothing, its like the battery is dying in second's, but is 1 year old was worked great a month ago!
Old Dec 3, 2009 | 09:02 AM
jlfrnce's Avatar
Ok i went out this mourning didnt touch anything and souded like it wanted to start for a secong but then just turns over, then sounds even more willing to start when i open the throttle up
99Ek_Fred
Jul 26, 2018 11:53 PM
KidKavika
May 8, 2013 05:25 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
flip1199
Feb 21, 2005 03:52 PM
b18c1eg2
Aug 21, 2004 12:28 AM
