Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Is there a trick to take out vacume line from brakebooster?
Old Dec 2, 2009 | 05:29 AM
Jaydeep's Avatar
Default Is there a trick to take out vacume line from brakebooster?
I am planning to take out vacuum line from brake booster and its not coming off because of vacuum. Is there any trice to it? I want to take it out so I can put some seafoam.
Old Dec 2, 2009 | 07:19 AM
Harlowe's Avatar
Function>Fashion
Default Re: Is there a trick to take out vacume line from brakebooster?
Pull the clip down with needle nose pliers the just pull on the hose. Maybe use vicegrips.
Old Dec 2, 2009 | 07:38 AM
mayfly's Avatar
pulll the clip down till its way past the flange it sits on, then use a screw driver to get inbetween the end of the hose and the brake booster, then wiggle it till its looose and pulll that bitch off
Old Dec 2, 2009 | 08:00 AM
Jaydeep's Avatar
I already pull clip down but its hard to put screw driver inbetween the end of the hose. I will try it again tonight when I go home.
Old Dec 2, 2009 | 08:05 AM
phatrick2332's Avatar
Take a pair of pliers and twist the hose on the fitting, this frees the seal and your good to go.
Old Dec 2, 2009 | 09:08 AM
jjspec's Avatar
Pump the brakes a few times(3-4) with the engine off and it will get rid of the vac.
Old Dec 2, 2009 | 11:27 PM
bomerman19's Avatar
I would not run seafoam through the brake booster vacuum seeing as it has a check valve in the line and you really don't want to be pouring liquid into a check valve
xwhitchx
Apr 14, 2009 08:06 PM
hondazccivic
Aug 21, 2008 11:41 AM
billyinse
Sep 5, 2007 02:40 PM
ntegls
Apr 19, 2003 09:26 AM
Sonny
Feb 9, 2003 09:40 PM
