need mechanical assistance 12/02/09
Check to see if the wires that lead to your starter are connected- and make sure the ground is tightened. Also, if that's not a problem, check to see that they're getting current when the ignition is turned on. If you are getting current then your problem is you need a different starter; 2 14mm bolts I believe, very easy change, you can probably save yourself $40 buy doing it yourself...
battery can be dead not holding anymore charge, when jump starting does starter work perfectly, like no hesistating or slow?... or alternator can be dead aswell. try borrowing a known working battery
There power on the whole car . And car works perfect when I push start it ... battery is new and tried 2 different ones .. doesn't clicks or cranks ...just ticking noise where the fuse box is at
get a hammer and beat on the flat side of the starter, it could be stuck,... if that doesnt work, get someone to try turning the key and another person to constantly tap on starter.
