ABS help
Old Dec 1, 2009 | 07:54 PM
curtis_k's Avatar
Default ABS help
I am looking into swapping the ABS set out from a 98 integra into a 94 bu i was wondering about the wiring the 94 has 16 pin while the 98 has only 8 any one out there can point me in the right path and definitely want to have abs just he smaller pump
Old Dec 2, 2009 | 05:33 AM
ahcapone's Avatar
Default Re: ABS help
The newer system uses a different computer and harness, I'm pretty sure it uses different sensors too. I'm not too sure but you might also have to replace the MC.
If you need the newer sensors I have some, I might have the computer too, not the harness.
Old Dec 5, 2009 | 09:13 PM
curtis_k's Avatar
not worried about the sensors i change to a type R suspension and i have those sensors but they plug up the exact same way just the plug up to the ABS pump i am worried about
Old Dec 6, 2009 | 12:51 AM
grjr's Avatar
you're probably going to need all the related ABS parts/wiring from a '98+ teg. Why not use a '97 or older system? seems like it would be easier to get that working in your car.
Old Dec 6, 2009 | 01:07 AM
I AM WEASEL's Avatar
The 94-97 and 98-01 ABS systems are totally different. You are going to need all the wiring as well as the abs computer. I don't know about the sensors however. I looked into doing this when I got my JDM HID front end, but decided against and just went ahead and did the ABS delete as it seemed like too much of a hassle. Could it be done, absolutely however it is up to you to determine if the reward benefits from all the time and possible headaches.
Old Dec 7, 2009 | 07:54 AM
Steven.'s Avatar
Supposing that all the 98 hardware fits directly and you want to plug it into your 94 wire harness just snip the plugs from a 98 and hardwire them to the wires from ur 94 just cut and wire with soder,electrical tape, wire clamps.
mdd
Mar 3, 2019 11:46 AM
Cheapshot1979
Suspension & Brakes
Apr 4, 2014 10:18 AM
halfkoreanboy
May 12, 2011 05:14 PM
Wdpfreak145
Apr 12, 2011 10:22 AM
Bnjmn
Oct 8, 2003 11:33 AM
