You havent seen this before. Lol
Ok so i bought a civic the other day, 89 si. turns out the alternator is bad on it. i knew this when i bought it, that is why i got it cheap.
well turns out the through bolt on the alternator is screwed. for one reason or another the end where the nut goes is grinded off completely! lol so its just a bolt,
well i tried punching it out but its not budging, sprayed some pb blaster on it and tried to punch it out again and still nothing.
any suggestions??? im lost on this one.
yea i tried to see if i can get the bracket out with the alternator on...but the alternator is in the way of one of the bolts and i cant get to it with it on.
plus im not working with a whole lot of room hear, i already took the shocks off and moved the knuckle a little to the side and a bigger mallet will not help me lol
Try puttin' a pin punch on the end of the bolt and hittin' that to knock the bolt out,if that don't work I say get the grinder and KILL that alternator
Can you get the other bolts out of the alternator?
I'm wondering if the bolt is seized in the alternator or to the bracket.
See if you can wiggle the alternator a bit when the broken bolt is all that holding it on.
Bah... who really cares.
Get out the grinder!!!
Fix_it_Yo_Self
Aug 2, 2017 12:03 PM
ShakesTheKlown
Jun 12, 2004 02:24 PM
GroundZer0 336
16
Mar 4, 2004 07:30 AM
