1999 4 door handle and lock problem
Old Dec 1, 2009 | 05:30 PM
hs545's Avatar
Default 1999 4 door handle and lock problem
The right rear outside door handle opens the door but does not return by itself, I have to push it in. The power lock does not work on this door either. It would be great if I had the part on hand when I remove the door panel. Anyone seen this problem before? Do the two problems have a common part failure or do I have two problems?
Old Dec 5, 2009 | 08:51 AM
PilotOnDubs's Avatar
Default Re: 1999 4 door handle and lock problem
the only way to tell, is to remove the door panel and inspect whats going on in there...
you may have a bad door lock actuator and maybe something else as well...but like i said, you wont know, till you take a look
Mychal71
Mar 20, 2022 01:32 PM
Tarlacon
Dec 14, 2008 03:54 AM
MetalHead4454
Nov 2, 2005 10:20 AM
.one lane
Nov 22, 2004 11:09 PM
blackflag188
Apr 26, 2004 12:23 PM
