CRX with b16a a fing on nuber 3
Old Dec 1, 2009 | 03:54 PM
Corvair64's Avatar
Default CRX with b16a a fing on nuber 3
did a B16 swap in a storig unit and it was running left it the with out running it fo ra mounth came back and it would not start, fuse plow out and i put a new fule pump in and dizz ( got off ebay) thinking that was the probem but now its only firing on number 3 cylinder. need help befor junking it. thanks
Old Dec 1, 2009 | 04:58 PM
SIred91's Avatar
Rainman
Default Re: CRX with b16a a fing on nuber 3
Um....what?
Old Dec 1, 2009 | 05:12 PM
Corvair64's Avatar
the motor is just fireing on number 3 cylinder and thats it and nothing els
Old Dec 1, 2009 | 05:35 PM
chandler's Avatar
alright, we need to know if the timing belt is set correctly, and if its spinning the rotor button. then we need to know what kind of mechanical skills you have befor we start telling you what kind of tests to do, i would personally use a noid light on all 4 injectors to see if they are firing, then see if the other three cylinders have compression or bad leakdown.
Old Dec 1, 2009 | 07:35 PM
213374U's Avatar
0x5359-0055
Community Builder
dewd... take your time and spell it out
Old Dec 6, 2009 | 09:22 AM
Corvair64's Avatar
timing belt is set correctly, the rotor button is spining. mechanical skills are no ase certification but know my way around the car.have not did the noid light but the compression is good
Old Dec 6, 2009 | 01:33 PM
Corvair64's Avatar
i use a noid light on all 4 injectors to see if they are firing and only 3 was firing with one other had a vary week firing.
91_da9
Sep 21, 2013 08:47 PM
civicmidwest_08
Jun 25, 2008 01:10 PM
nboost
Feb 6, 2006 12:48 AM
94SuperLudeSI
Feb 8, 2004 08:36 AM
