car willnt start, need advice!
Old Dec 1, 2009 | 10:26 AM
KGB_JDM's Avatar
Default car willnt start, need advice!
So about 3 weeks ago, i sent my car to get painted over at my friends who does it on the side. The car was running fine besides the battery needing to be charge. I got the car back and i went to go start it up and nothing...it sounds like it turning over but willnt fully start, i called up my friend asking if he had trouble starting it and he said the first day he got it he started it got it into the booth and it died out of nowhere, so he just kept pushing it in and out of the booth. I pulled the valve cover off and pulled the spark plugs and they were covered with oil down at the bottom and were in need of replacement. The car has 160k and i think the dude before didnt take care of the car, beside changing the oil every 3k. I replaced the spark plugs, the valve gasket thinkg maybe it was leaking and the spark plug wire with some red ngk wires....went to start it today after putting it together and still nothing....so i need some advice on what else could be wrong. maybe someone else has had this problem any help will work thanks....
Old Dec 1, 2009 | 11:28 AM
Moi Zver' (GSR)'s Avatar
Default Re: car willnt start, need advice!
check if u get power from fuel pump, if not its ur main relay and make sure the battery is good.
Old Dec 1, 2009 | 11:50 AM
KGB_JDM's Avatar
ok ill try that when i get back to my place...thanks man
dailydriven91ex
Jul 20, 2004 11:42 AM
dailydriven91ex
Jul 19, 2004 06:50 PM
FourthGenHatch
Nov 18, 2002 02:00 PM
hwnstyle21
Oct 16, 2002 09:32 PM
