H22a NA build
Old Dec 1, 2009 | 08:29 AM
coloradolude's Avatar
New User
Default H22a NA build
whats up everybody. i have a 92 prelude that im putting an H22a in and i wanna build it NA. Does anyone have any suggestions on what mods i can do to get the most out of my motor. any thing helps thanks
Old Dec 1, 2009 | 08:31 AM
ilikehonda's Avatar
Default Re: H22a NA build
look to sig for my opinion
Old Dec 1, 2009 | 08:37 AM
New User
sorry im new what is sig
Old Dec 1, 2009 | 08:45 AM
CerealKiller's Avatar
H22 ported and polished head, ssfv, s2p1's, s2 cam gears, euro r tb, precision 780cc, boldfab header, 3in apexi ws2.....233whp
Old Dec 1, 2009 | 09:06 AM
ilikehonda's Avatar
look directly below my post. you will see my mods. also do a search for h22 na or allmotor etc. there have been a lot of posts about this. you will find a lot of information about this topic.
Old Dec 1, 2009 | 01:55 PM
f20b jones's Avatar
skunk2 stage 2 cams
port and polished head
h23 crank
12.3 compression
port and polished stock intake
rmf header
rc550 injectors
253 hp 181tourge
stock throttle body
bull crap exuast
Thats what i have and its realy cheap to do hope that helps.
Old Dec 1, 2009 | 04:47 PM
curioso's Avatar
Originally Posted by f20b jones
skunk2 stage 2 cams
h23 crank
12.3 compression
rmf header
rc550 injectors
253 hp 181tourge
stock throttle body
bull crap exuast
so if i do all this and just put the h23 crank i get to 12.3 compression or did u use different pistons?
Old Dec 1, 2009 | 09:15 PM
Mike95lude's Avatar
What specific goals do you have? What's your budget? If you don't define these things you're going to get random suggestions and it won't be that useful.
Old Dec 1, 2009 | 11:38 PM
HdeucedeuceA's Avatar
Search my friend.
ilikehonda, do you have a dyno chart of your set up? I'm building a head with some Pro 1's and am trying to gather as much info as possible.
Old Dec 2, 2009 | 09:52 AM
ilikehonda's Avatar
Originally Posted by HdeucedeuceA
Search my friend.
http://i76.photobucket.com/albums/j3...n/IMG_7811.jpg
that is an old one that is not corrected.... but you can see the huge gains over just boltons (the smaller graph)
Old Dec 2, 2009 | 12:43 PM
^Did you degree the cams in? Also what IM are you using? I think I've seen the dyno before somewhere.
Old Dec 2, 2009 | 02:05 PM
ilikehonda's Avatar
no the cams are not degreed nor were they advanced....set at 0,0. clutch let loose a few runs later so we never got that far....and ive yet to tear the car down. so its been sitting for more than a year lol....
stock intake manifold with butterflies removed.
Old Dec 5, 2009 | 06:53 PM
f20b jones's Avatar
My compression is 12.3 but you can get flat faced valves shave the head and run type s pistons and get real close.
nemoyan
May 18, 2009 05:02 PM
DunnDunn
Oct 7, 2006 06:06 AM
AnclyT
May 10, 2005 02:27 PM
JDMH22Prelude
May 4, 2005 09:27 AM
Jago
Oct 10, 2003 10:28 AM
