Transmission & Drivetrain Gearboxes, Differentials, Clutches
Obx and innovative axles?
Old Dec 1, 2009 | 07:11 AM
boostedb20ek's Avatar
Default Obx and innovative axles?
I need advice or just someone to tell me if these axles are any good. I have a turbo b series building to get around 450whp. Came across the obx axles which are rated at 1000whp and the innovative which are rated at 800whp. I know it's kinda an overkill but I want something that I wouldn't have to replace again if I wand to build a more powerful motor. Both are around 800 bucks, leaning towards the innovative only because I have innovative mounts. Any advice is appreciated
Old Dec 3, 2009 | 04:50 PM
insanemike24's Avatar
Default Re: Obx and innovative axles?
i dont know much about the obx axles but i know that innovative axles are made in the USA with great metal and also the innovative axles are made for and even swap(you dont have to change the spindle from the hub) which means your not adding wait to the drivetrain these axles are proven
Old Dec 4, 2009 | 05:46 AM
Thanks for the advise. Does anyone have experience with innovative axles?
Old Dec 4, 2009 | 08:45 AM
Civic89stdB16's Avatar
i know of alot of people on stock axles making anywhere from 160whp to 850whp and never broke a axle and they have years upon years on the same axles. Its just ur driving style and dont side step at the track.
Old Dec 4, 2009 | 09:12 PM
I've been through 2 sets of stock axles. It's hard to beleive anyone launching with that much hp for so long and not snapping axles.
Old Feb 16, 2010 | 08:38 AM
HAMOTORSPORTS's Avatar
It depends a lot on the way the driver launches the car too. The axles have to be preloaded if you want them to last. Either way though, the Innovative Axles are top notch!
Old Apr 23, 2024 | 07:24 PM
Tomas Calderon's Avatar
Default I have a problem with my 2nd gen crv
I have a 2nd gen cr v that has a death wable I replaced the cv axel and and it didn't change the problem I figured out were the wable is coming from it from the left hand side were the cv and transmission meat my question is what can I do to fix this problem it started to leak fluid and I'm about to put a new seal and don't want to waist money on part after part do I need to fix the inside of the tranny or will the seal fix the problem
Old Apr 23, 2024 | 08:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The axle seal will stop the leak, but it will not fix the vibration.
TypeRod
Aug 21, 2002 10:48 PM
