fs:schwitzer aka borg warner turbos
Old Dec 1, 2009 | 06:36 AM
kowcain's Avatar
Default fs:schwitzer aka borg warner turbos
im located in charleston
you can pm me.
price - 600 each or trades for sohc stuff
got these from a uncle that works for a big name engine company, they ran them for 5min for testing a motor.
just seeing what i can get for them would take trades lmk.. here are some pictures.
Model spec.: S200W
Turbo maker: Schwitzer
Orientation α (compressor housing): 252°
Orientation β (turbine housing): °
Axial play min./max.: 0,05/0,1 mm.
Radial play min./max.: 0,41/0,55 mm.
Clearance min./max. (compressor end): / mm.
Clearance min./max. (turbine end): / mm.
Power kW/hp: 330/443 at 2100 rpm
cooling - oil fed
what it came off of
Engine: BF6M1015C
Engine displacement: 4.91 litres
Fuel: diesel
hopes some of this helps.
Old Dec 1, 2009 | 07:03 AM
azandford's Avatar
Default Re: fs:schwitzer aka borg warner turbos
can you provide any more info on these turbos? Is schwitzer a subsidiary of borg warner?
Old Dec 1, 2009 | 07:32 AM
kowcain's Avatar
from the research ive done so far. schwitzer and borg warner are the same company. ive been trying to find a place to find more info with the numbers on the turbos but havent had any luck so far.. but as soon as i find more info i'll include it in here. i have to wait for him to get home so i can find out the specs of the turbos all he did was drop them off this morning and went to work.. i couldnt ask him anything.
Old Dec 2, 2009 | 04:10 AM
kowcain's Avatar
updated
Old Dec 2, 2009 | 05:14 AM
pettyboy69's Avatar
im guessing these cam off a diesel by the look of em correct?
Old Dec 2, 2009 | 06:34 AM
kowcain's Avatar
yep
Turbo200
Jun 28, 2005 06:24 AM
Don Johnson
Sep 22, 2004 04:55 PM
Acura_I-RS
Jul 27, 2003 05:51 PM
E-Rok
Dec 23, 2002 06:09 PM
