Transmission help!!!!!!!
Hey guys, well my tranny seized and I bought a new one off ht. I had my mechanic install it and he says this one is seized ttoo. It will not shift at all or go in any gears, locked up. This is hydro btw, I want a second opinon. Please help I need my car and I hope I didn't buy a broken tranny
did you check all other possibilties? slave cylinder, master cylinder, and clutch...if you did then its time to open up one of them to see if it really is seized which is kind of rare. also check your tranny fluid level and back mount
Rebuild trans?
Take the old one apart. You've got nothing to lose at this point.
Buy a trans from a salvage yard that has some kind of warranty.
Umm how do you test shift it, and how could i possibly buy a tranny that is seized up like my old one, that sucks the guy told me it was good when i bought it.
Thanks for your input.
But what do YOU think could be wrong, after he installed it he said the shifter was frozen and everything was locked up, and he couldnt even shift. New clutch just put in too and i believe a slave cylinder
I would guess installation error. The shifter should move somewhat. Did this transmission physically look reasonable? Was they excess corrosion or anything?
Guessing is the best I can do with those details.
Yes the transmission looked good. No corrosion or anything pretty clean, and it still had plenty of tranny fluid in it. Could an incorrect clutch install do this too? Anyways any good links for tranny install, i think i will ask him to let me take a look.
