Balance shaft problems
Old Nov 30, 2009 | 04:51 PM
daymkimchee's Avatar
Default Balance shaft problems
can somone explain what the balance shafts do and why they need to be timed a certain way?Last night i changed my timming belt on the f22 and i got curious n took off the gear on the rear balance shaft.When it came off i realized i had no way of telling how the gears were lines up so no im worried the timming on the balance shafts going to be off
Old Nov 30, 2009 | 05:14 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Balance shaft problems
You can leave the belt off if you want for the balance shafts, they smooth out the motor's movement. Some people use balance shaft eliminator kits to remove the rotating mass and others just take off the belt.
Old Nov 30, 2009 | 07:19 PM
nus_dogg's Avatar
^^ what he said.
Reason why some ppl preferr to use the eliminator kit is to remove some weight by taking those balancer shafts out for good.
Old Nov 30, 2009 | 11:34 PM
really i see.So you think i should try n take everything appart to try n figure out which way the gear was suposed to go back on or just eliminate them.
1sickef9
Nov 24, 2009 07:18 AM
Dravenm4
Feb 14, 2009 02:18 PM
Nathan007
Aug 23, 2007 05:33 PM
BB6racer
Sep 5, 2005 07:33 AM
Neondog82
Oct 23, 2004 01:04 PM
