having distributor trouble...
Old Nov 30, 2009 | 02:38 PM
B16Blake's Avatar
Default having distributor trouble...
i bought a "brand new" distributor and the timing was so far retarded on it that my car wouldnt idle and it would rev very slow and shot massive fireballs out the exhaust... i bought it off ebay and messaged him and asked for a REFUND. sent him back the distributor but instead of refunding me, he sent me another one. this one is better, my car idles, but it still feels like the timing is a bit retarded, even though i have the timing set to full advance on the distributor. i have another used one i bought that works fine, but both distributors is causing my car to throw a CEL code 8 (top dead center sensor). even the "brand new" one does. also, why would my car be throwing a CEL code 8? would any other bad sensor set it off? FYI its an OBD0 B16A with PR3 ECU
Old Nov 30, 2009 | 04:17 PM
zrickety's Avatar
Default Re: having distributor trouble...
it's probably the wiring on the car. check the plugs at the distributor and the ecu. you may have a loose/broken/corroded wire or pin. then check the timing with the jumper and a timing light
Old Nov 30, 2009 | 09:18 PM
B16Blake's Avatar
it may be a problem with the wiring... im just waiting for my Rywire harness to get here so i can figure out for sure what the problem is. also, the first distributor that came with my swap wasnt throwing any CELs until it took a crap. im checking the timing tomorrow.
any other help or suggestions would be greatly appreciated
Kaminsky
14
Aug 7, 2015 03:03 PM
meallout
Mar 19, 2009 11:34 AM
strategy400
Aug 11, 2008 03:49 PM
ek fan
Jul 4, 2008 04:47 AM
rhdjdmda6
Jul 13, 2006 04:52 AM
