CA wayne-_-built 97 acura integra 400 whp daily driver fully built & sleeved
SOLD
built by wayne at JWR
selling for the owner
97 acura integra ls
clean title
141k
fresh paint victory red
98+ front bumper
hid's
no ac
no ps
exterior
fresh victory red paint job
no dents or dings
98 front bumper
interior
recardo's
stock backseat's
orignal cluster
suspension
skunk2 coilovers
kyb shocks
stock sway bars
powerplant
block
jwr race engine's blue print lsv the wayne special
84.5 golden eagle hd sleeved b18
golden eagle head studs
golden eagle main studs
manley 9:1 cpr 84.5 slugs
manley turbo tuff rods
89mm cryo treated & micro-polished crank std.
acl race series rod & main bearings with new thrust washers
new p73 oil pump
new p73 water pump
golden eagle lsv kit with 84.5 oem head gasket
head
96 p72 gsr head
supertech valve springs
supertech retainers
supertech br valve guides
supertech intake & exhaust valves std.
sk2 manifold
hondata intake manifold gasket
golden eagle fuel rail
aem fuel pressure reg
marshal liquid filled gauge
stock cam gears
96 gsr cams
innovative mounts
everything bought bnib from camp 1320
transmission
original s80 shifts like butter
act stage 2 clutch kit
autozone lifetime warranty axles
turbo kit
Fast Int. top mount 321 steel t3/t4 flanged
borg & warner 70/62ex car will be sold with a bnib exact model
mines 44mm v band racegate 15 psi spring
ebay intercooler piping kit 2.5/3 in
rc 750 injectors
gm 3 bar map sensor
hondata s300
hondata boost solenoid/boost by gear
hks ssq bov
turbo blanket
3in down pipe with flex
magna flow 3in muffler
red horse an -10 fittings, stainless return line
engine was started and broken in on the dyno
built by wayne for ABUSE
no leaks
no problems
no smoke
tuned by bubba
399 whp 330 wtq at 14.9 psi PUMP GAS
i am sure i left something out i will update
http://www.youtube.com/watch?v=uRu4JokdgWc
before the paint
make an offer
818-919-2364 text please
97 acura integra ls
clean title
141k
98+ front bumper
hid's
no ac
no ps
exterior
no dents or dings
98 front bumper
interior
recardo's
stock backseat's
orignal cluster
suspension
skunk2 coilovers
kyb shocks
stock sway bars
powerplant
block
new p73 oil pump
new p73 water pump
head
96 p72 gsr head
supertech retainers
sk2 manifold
stock cam gears
96 gsr cams
innovative mounts
transmission
turbo kit
rc 750 injectors
gm 3 bar map sensor
hondata s300
hks ssq bov
turbo blanket
no leaks
no problems
no smoke
tuned by bubba
before the paint
make an offer
ttt
