Valve cover grommets?
Old Nov 29, 2009 | 07:09 PM
jordanitr's Avatar
Default Valve cover grommets?
So how do you get these damn things over the valve cover bolts? I had to rip the old ones off the bolts and cant get the new one's on.. HELP. I bought Felpro gasket set.
Old Nov 30, 2009 | 02:46 AM
AFAccord's Avatar
Default Re: Valve cover grommets?
Push harder... seriously.
Old Nov 30, 2009 | 04:44 AM
nus_dogg's Avatar
Yup, unless they're bad quality. haha
Old Nov 30, 2009 | 06:56 AM
redtop8726's Avatar
New User
try lubing the grommets up with wd so they will slip on easier but wipe them off afterwards
Old Nov 30, 2009 | 07:31 AM
jordanitr's Avatar
I tried to use a rubber mallet and still cant get them over the bolt. Is FEL PRO just garbage gasket set? This is my first Accord.
Old Nov 30, 2009 | 07:34 AM
8VEYBEYB's Avatar
please tell me you aren't actually trying to push them OVER the bolts , you must take the bolts off and then put them on. I have fel pro and mine worked just fine.
If you are trying to push them over the bolts you might want to get new ones as you've probably beat them to death .
Old Nov 30, 2009 | 09:03 AM
jordanitr's Avatar
No I did not push them over the top, the bottom. I gave up and went got honda ones and they went in just fine.
Casey Enk
Aug 12, 2017 02:18 PM
BondoBuilder
Mar 1, 2010 10:59 AM
PatrickGSR94
Nov 15, 2008 05:40 PM
smores
Jul 4, 2005 06:52 PM
EJ8 GSR-T
16
Nov 12, 2004 09:22 PM
