Wtb d16 oil pan/cap 92 hatch tails...
I am about to boost my car and want a new oil pan for my D16Y7 NOT A D16Z6. It can be used but in good condition. I have the flange don't need that.
Car is a 96 civic dx d16y7 sohc. I also need oil cap. Would prefer aftermarket.
Also after a set of jdm or oem tails for a hatch just the outers.
Reply to thread or email me at mcguire6799@yahoo.con with pictures and price shipped to Bloomington Indiana. 47403
A few things you may need to know about y8 oil pan:
1) It is deeper/taller than y7 oil pan so it holds slightly more oil.
2) It is made of aluminum vs. steel so it disapate heat much better and it has small fin type surface.
3) can be use on y7 block but need to use y8 oil pan gasket.
4) will not fit on 88-95 D series blocks.
y8 will not work with y7 oil pan because the y8 oil pick up is much longer so it will hit the bottom of the y7 oil pan before it can even sit flush with the y8 block.
You can use y8 oil pan on y7 block, but not the other way around.
what about a d16y5 oil pan already tapped for the oil return line?.........i also have a 3" ceramic coated down pipe for a single cam with a 4-bolt turbo flange
