Lots of 92-95 Stuff H22 and D16Z6 Head and more
Old Nov 28, 2009 | 01:37 PM
x32laro's Avatar
Default Lots of 92-95 Stuff H22 and D16Z6 Head and more
Keep in mind I have alot more parts than you see pictured.
Please be polite and bump the thread for me.
If you bump the thread and buy something from me I will cover the paypal fees.
I am paypal verified with over 5000 transactions.
May trade for something of value...What ya got?
ICEMAN
[b]Between 1 and 1.5 carats of diamonds. Yes they are real. Sold for $2200.00 on sale....MAKE AN OFFER!!
One pair of Oakley Oil Rigs. With Ghost writing on frame.
No scratches like new.
Mirrored lense
The Oakleys were bought new Oct 27th of 2009 From sunglass hut.
I have the Oakley bag for the Oil Rigs.
And a pair of Oakley Fives Squared.
Fossil Watch.
Has a little blemish at 10 oclock. On inside of crystal
I have a d15 vtec from a 92 cx hatch back. Rattle/knock in the lower end.
Good head, vtec valve cover. Was still running when pulled. I also have a 91 CRX si D16a motor. Runs.
I am parting this car out. 92 civic cx. 5 speed car.
Never been wrecked or painted.
May sell whole for the right price.
I got a low milage 1998 H22 VTEC COMPLETE TOP END for sale.
Head with valves. I have the cams and caps also.
Looks rusty in pics but it is not. Will take more photos if you need them.
H22PARTS REMOVED FROM A 98 PRELUDE
H22 HEAD
I have the cams and gears also.
PLASTIC INJECTOR WIRING HARNESS COVER
H22 WATER OUTLET FOR THE HEAD
H22 ENGINE HARNESS
H22 THROTTLE BODY
H22 HEADER
Perfect Cond.
Also have :
cams and gears
In the meantime feel free to contact me with your civic needs.
You can also text or call me at 662-305-5000 up until 3 am.
Thank you.
Several ignition switches...Wiring and lock cyls with O.E.M Honda keys.
95 Passenger Air Bag (BLACK).
96 Integra Tilt Column.
96 Integra Ignition switch with OEM key.
96 Integra black steering wheel.
96 Integra SRS Clockspring.
96 Integra cruise control buttons.
96-00 Tilt Steering Column.
92-93 Gray glove box.
92-95 Coupe and Hatch Door glass
92-95 Shift Linkage
92-95 Alternator
92-95 Hood Latch
92-95 D Series VSS
92-95 Hood Release Cable
92-95 Hood Release Handle
92-95 Hatch Rear interior wiring harness.
92-95 Minty Headlights L and R.
92-95 Hatch complete lock and key set. Doors, hatch, ignition.
92-95 EG Hatch Gray Carpet.
Plus much much more.
The D16Z6 had 110k miles on it.
D16Z6 HEAD.
D16Z6 INTAKE MANIFOLD.
D16Z6 UPPER TIMING COVER PIECE.
Shoulder bolt included.
92-95 CIVIC PEDALS
D16Z6 FUEL RAIL.
D SERIES CRANK PULLEY BOLT
D16Z6 FUEL PRESSURE REGULATOR.
D SERIES IACV With only 10k miles on it.
[B]92-95 COOLING FAN HARNESS[B]
D16Z6 VTEC SWITCH with 110K MILES.
Pictures soon
B16A2 INNER TIMING COVER PIECE
SONY ERICKSON WALKMAN for AT&T
Works perfect and comes with memory cars and 2 chargers.
P05 ECU FOR 5 SPEED
VIRGIN P28 ECU FOR 5 SPEED
$125.00 Shipped.
92-95 CIVIC UPPER WINDSHEILD MOLDING
92-95 CIVIC UPPER WINDSHEILD MOLDING CLIPS
92-95 CIVIC WINDSHEILD MOLDINGS
OWNERS MANUAL FOR 92 CIVIC
92-95 CIVIC D SERIES THROTTLE CABLE
92-95 HEAT AND A/C CONTROLS
92-95 OUTER DOOR HANDLES
Have fronts and rears from 4 door
01-02 CIVIC TILT STEERING COLUMN
92-95 CIVIC TILT STEERING COLUMN
92-95 STEERING COLUMN MOUNT
92-95 CIVIC STANDARD STEERING COLUMN
STEERING COLUMN JOINT
01-02 CIVIC IGNITION SWITCH w/ KEY and WIRELESS REMOTE
GRAY CENTER CONSOLE
Minty Clean
92-95 GRAY DASH
Removed from a 92 no pass air bag.
UNDER DASH TRIM
Grey
UNDER DASH TRIM
Black
BLACK INNER HANDLE TRIM.
92-00 WIPER SWITCH
FUSE ACCESS DOOR
Black
FACTORY AIR FILTER BOX
Filter Included
POWER MIRROR
Right Side - 2 door and Hatch
92-95 CIVIC HOOD HINGES
MAIN RELAY
D SERIES STARTER
Automatic Transmission
Also have one for a 5 speed manual
92-95 INSTRUMENT CLUSTER
STOCK D SERIES INJECTORS
$8.00 each shipped
LEFT FOG LIGHT EG. Lense busted. Bracket good light is prob good.
UNDERHOOD FUSE ASSORTMENT
AIR BAG SRS REEL CLOCK SPRING
Removed from a 2001 civic
WIPER SWITCH FOR 96-00 (EK) HATCH w REAR WIPER
I also have one for the 2 and 4 door.
D SERIES POWER STEERING BRACKET
92-95 CIVIC SUNROOF RELAYS
92-95 DOME LIGHT
Removed from a 92 CX HATCH
D SERIES VTEC
AUTO TRANSMISSION FLYWHEEL BOLT
HOOD/TRUNK RUBBER ADJUSTERS-STOPPERS
94-95 EG AIRBAG HARNESS
92-95 EG TAN CENTER DASH VENT
92-95 GRAY EG CENTER DASH VENT
92-95 GRAY EG HANDLE TRIM
88-00 WINDOW CRANK
Have one tan one and one gray one in stock
92-95 GAS DOOR FROM HATCH
92-95 REAR HATCH STRUTS
92-95 GAS AND HATCH RELEASE TRIM
Gray in color
92-95 2 DOOR OR HATCH GRAY SPEAKER COVERS
O.E.M. 5 SPEED SHIFT ****
BLACK 01 CIVIC STEERING WHEEL
Minty clean
92-95 STEERING WHEEL BROWN
92-95 AIRBAG BROWN
Also have a gray one.
96-00 IGNITION HARNESS
96-00 IGNITION SWITCH WITH KEY
92-95 UNDERHOOD FUSE BOX COVER
CLUTCH RESEVOIR and BRACKET
GREY EBRAKE BOOT
SUNROOF RELAYS
92-95 CIVIC WIPER TRANSMISSION
92-95 CIVIC CLUSTER BEZEL
POWDER COATED TOW HOOKS
96-00 INNER DOOR HANDLES
From 2000 civic Si Minty clean
REAR PLATE TRIM PANEL
LEFT SIDE HATCH TAIL WITH BULBS AND HARNESS
Have a full set from 92-95 4 door sedan and 92-95 hatch
You can pm, call or text me @ 662-305-5000 for more details.
Old Nov 28, 2009 | 10:40 PM
x32laro's Avatar
Default Re: Lots of 92-95 Stuff H22 and D16Z6 Head and more
Bump
Old Nov 28, 2009 | 11:29 PM
DA3DC2's Avatar
No Sales Forums
how much for z6 head?? no solenoid maybe mani
Old Nov 29, 2009 | 06:13 AM
Fibercation's Avatar
ttt for you...half that stuff i end up junking when i part out.....too much nickel and dime stuff...but def a nice thread for people that need small items!
Old Nov 29, 2009 | 06:24 AM
x32laro's Avatar
pmed
Old Nov 29, 2009 | 11:01 AM
x32laro's Avatar
Bump
Old Nov 30, 2009 | 07:49 AM
x32laro's Avatar
Bump
Old Nov 30, 2009 | 10:35 AM
x32laro's Avatar
Bump
Old Nov 30, 2009 | 09:45 PM
thatcivic96's Avatar
bump for good business.
Old Dec 1, 2009 | 07:29 AM
x32laro's Avatar
Thank you
Old Dec 1, 2009 | 05:08 PM
x32laro's Avatar
Bump
Old Dec 2, 2009 | 06:44 AM
x32laro's Avatar
Bump
Old Dec 2, 2009 | 10:48 PM
x32laro's Avatar
Bump
Old Dec 2, 2009 | 11:02 PM
Pr0j3cT95dX's Avatar
PM SENT!
Old Dec 3, 2009 | 12:25 AM
92bseries's Avatar
do you have an obd1, under dash harness??
Old Dec 3, 2009 | 06:45 AM
x32laro's Avatar
Sold it.
Old Dec 3, 2009 | 07:09 AM
Yonick90's Avatar
bump. already sent the PM so you know what i want, trying to do my conversion on my 95 civic all the parts you have would help make this swap a lot easier! ill keep in contact wit you
Old Dec 3, 2009 | 12:49 PM
x32laro's Avatar
Bump
Old Dec 4, 2009 | 07:07 AM
x32laro's Avatar
bump
Old Dec 5, 2009 | 12:59 PM
x32laro's Avatar
uppppppppp
Old Dec 6, 2009 | 09:29 AM
x32laro's Avatar
bumpo
Old Dec 6, 2009 | 12:32 PM
x32laro's Avatar
bump
Old Dec 7, 2009 | 01:07 PM
x32laro's Avatar
bump
Old Dec 8, 2009 | 03:46 PM
x32laro's Avatar
bump
Old Dec 8, 2009 | 06:57 PM
x32laro's Avatar
bump
