FL ALL MOTOR CLEAN HATCH
Old Nov 28, 2009 | 04:54 AM
Don JD's Avatar
Default ALL MOTOR CLEAN HATCH
IF YOU DONT LIKE THE CAR, THE PRICE, OR ANYTHING FROM THIS THREAD, KEEP UR FEELINGS AWAY FROM HERE.
Price is OBO. Im willing to take rims off, sytem off, torque damper off, all K&N filters, Fuel Rail System, Carbon Fiber Spoiler, Optima Battery, Radiator and hoses. and maybe some more in order to lower price down for someone really interested
PRICE IS 6300 OBO
I WILL TAKE DB8'S, EM1, OR EK HATCH'S FOR TRADES. PLEASE NOTHING ELSE
CHECK PICS HERE
eg clean pictures by chapabig - Photobucket
If yall interested holla at 561-3061518 or pm me with any questions.
177K MILES ON CLUSTER
20K MILES ON ENGINE
CAR HAS A/C AND P/S
THIS CAR IS MAY DAILY AND IT RUNS HARD
Car was built by KAW (Kenzi Auto Works) in Kendall Florida. Everything was done perfect
Exterior: overall 9.5 out of 10
- Fresh Milano red paint 9 out of 10 (front lip has little chips and hood has a little chip where clear coat took a crap. someone spilled a little degreaser on it and let it dried)
- Body is 10 out of 10. it has no dents.
- Type R front lip
- Type R rear Lip
- Manual Spoon Mirrors
- Real carbon fiber duckbill spoiler
- Amber corner lights
- Black housing headlights
- 3000k HID headlights (yellow) (one ballast broke) i also have some 8000k bulbs
- Yellow fog lights
- 17" xtatic Black with chrome lip rims (No curb rash or scratches)
- 215-40-17 Nexxen 7000 brand new tires in the back
- 205-40-17 Nexxen 5000 brand new tires up front
Interior: overall 9.5 out of 10
- Carbon fiber Real Momo Steering wheel
- Gray Door panels in excelent condition
- Dark grey EG front seats. (driver side has a hole)
- Rear gray seats in perfect condition
- Rear grey cargo cover in perfect condition
- Ex cluster with 175000 miles
- Clock Block off plate
- Front dash wihtout Airbag
- Some silver pedals (just there cause i dont like the oem look)
- Dark gray carpet 8 out of 10
- Perfect condition plastics all the way around
- Cargo area plastics have scratch marks
- Type R shift booth
- Skunk 2 Shift ****
Suspension:
- Dropzone Coilovers
- Koni non adjustable shocks
- Gold Blox rear LCA's
- Hard Race Rear camber with pillow ball bushings (this aint just a regular camber kit with rubber)
- Hard race hard rubber bushings on fron LCA's
- Skunk 2 front camber kit
- Lower front bennen Strut bar
- Three point upper front bennen strut bar
- Upper rear Bronze Strut bar
- Extended front Wheel studs
Brakes:
- Si brakes all around
- Steel braided brake lines
- Cross not all the way thru drilled rotors. just for looks (drilled rotors only make braking worst by not letting disipate the temperature on a bigger surface)
- Fresh ceramic brake pads
ENGINE:
B20z2 bottom:
- Arp rod bolts
- LS crank
- Shootpeen LS rods
- Hone big end of rods
- Hone cilinder
- CTR Pistons
- Balance entire rotating assembly
- ACL bearings
- Golden Eagle Sandwich oil plate (includes niple to provide another oil line to head)
- Steel braided Oil hose for use with the golden eagle plate
- Golden eagle head gasket
- OEM piston Rings
- MOROSO Oil pan with respective gasket
93 GSR head (Uses the same bolt pattern as a B16 and ITR head):
- Port and polish
- Skunk 2 valve springs
- skunk 2 retainers
- skunk 2 cams
- Golden eagle adjustable cam gears
- OEM valve seals
- ITR Intake manifold
- ITR Trhotle body
- MOROSO cosmetic valve cover with respective gasket
- Greddy Oil Catch Can conected to head, block and oil pan
- AEM Fuel rail with gauge
- AEM fuel regulator
- RC 550cc Injectors
- walboro fuel pump
- NGK Sparks
- Oil pressure gaughe with steel braided lines
- Steel braided oil lines
- Hassport Engine mounts
- Engine torque damper
Breathing system LOL:
- K&N air filter
- K&N oil catch can breather
- K&N transmission breather
- Hytech replica headers
- High flow cat
- Replica N1 Mufler
- 2.5" Piping all aorund
Tranny
- B16 tranny with LSD
- Stage 2 clutch
- Fidanza flywheel
Cooling System:
- Samco Red radiator hoses
- C&R Full radiator
System:
- Pioner flip up indash dvd-radio 7" screen
- Infinti 6.5" speakers up front and back
- 10" kicker Sub in custom box
- Sony Explode Amp
- Optima Yellow top battery mounted in the trunk
- 4 gauges wires all aorund for power input and output
- B16 ECU with 2 chips. 1 chip for 93 octane at 203 whp and the other for race fuel at 229 whp
I will defenitely recomend tunning car again, i know this baby is capable of more power
I hope i did not forget anything but most likely i did
Thank you for your interest
Old Nov 28, 2009 | 05:08 AM
srt4mike's Avatar
Default Re: ALL MOTOR CLEAN HATCH
Looks nice. GLWS
Old Nov 28, 2009 | 07:53 AM
Don JD's Avatar
Originally Posted by srt4mike
Looks nice. GLWS
thx
Old Nov 29, 2009 | 12:33 PM
dirtyharryhatch's Avatar
A Digital Frontier
do you have dyno sheets?
Old Nov 30, 2009 | 04:13 AM
Don JD's Avatar
I dont, you can drive it yourself and know the car has some power. just by using stock b20 and stock vtec head you can get around 180whp (correct me if im wrong)
Old Nov 30, 2009 | 11:07 AM
A Digital Frontier
naw i was just asking to see if its seen dyno time. street tuned? idk if u interested but i have a 1999 civic dx 3dr im the 2nd owner check it out in my garage and lmk if ur interested i know its stock but the car is IMMACULATE.
Old Nov 30, 2009 | 03:43 PM
Don JD's Avatar
Sure, let me know how much u gonna throw on top
Old Nov 30, 2009 | 03:46 PM
A Digital Frontier
sure! PMd.
Old Dec 1, 2009 | 04:39 AM
Don JD's Avatar
ttt
Old Dec 3, 2009 | 07:31 AM
Don JD's Avatar
ttt
Old Dec 6, 2009 | 04:31 PM
Don JD's Avatar
ttt
monge
Feb 22, 2013 12:23 AM
clutchkickphoto
Nov 21, 2012 04:11 PM
Don JD
Nov 28, 2009 07:51 AM
J.WOLFE~v1.0
Mid-Atlantic (Sales)
Jul 5, 2009 02:20 PM
My_EFsedan
Northern California (Sales)
Jul 1, 2009 01:48 AM
