91 civic alternator pulley
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
hey guys looking for a 91 civic alternator puley, i'm having to move the alternator on my 86 accord hatch, One of the SU fuel bowls sat an inch over the alternator, that's a very bad thing with a bottom outlet bowl and rubber hose, i'm putting the alternator where the AC compressor was, I have it all figured out, but I need the civic alternator pulley, I'm driving the alternator from the AC belt groove on the crank pulley, and that belt matches a 91 civic alternator perfectly. AS far as the old alternaor, I'm gutting a bad one, down to the case, the shaft through it, and the case bearings. this will act as an idler for the water pump, but will be an empty spinning shell.
Moultrie, I just need the pulley itself, i have a brand new alternator for the accord, I'm hoping they have the same shaft, or i have some machine work to do. Most hondas of this era have the same shaft diameter on things like this,
I have a bad alternato from a 1986 Civic SI, a pulley from a 1978 Civic and a 1992-995 pulley. I can get you a pulley from a 88-91 Civic from a local yard if I go today or tomorrow. Later.
good deal!! i have to get it mounted on the alternator then i can shim the brackets to line up the belt. it fits in there really well, i modified one of those chrome gm arms by cutting it off, and redrilling the holes, it makes a nice adjusting arm right on the old cast iron ac bracket.
mjrino
Feb 18, 2007 08:31 AM
