about sitting for extended time.
Old Nov 27, 2009 | 08:11 AM
rattlecannedEF's Avatar
Default about sitting for extended time.
so i just started and drove my car for the first time in about 2 months. is it normal to smoke a little?
also, as soon as it is warmed up the rpms drop to about 500 and it sounds like my car is gonna die.
any help is appreciated.
93 integra b18a
Old Nov 27, 2009 | 11:35 AM
98gsrintegra's Avatar
Default Re: about sitting for extended time.
most hondas are known to smoke at startup,
Old Nov 27, 2009 | 09:39 PM
thewrai6th's Avatar
93 integra b18a
Leaky valve stem seals can cause oil to drain down into the cylinders after an extended period of time. If the smoke goes away, you're probably safe for now. The rough idle could be any number of things. Check your plugs for signs and search on iacv.
If the smoke smells like coolant, you might have a bad headgasket.
Old Nov 28, 2009 | 04:38 PM
the smoke smells like stale gas. could that be why it idles funny?
Old Nov 29, 2009 | 04:52 PM
cl3an_98gsr's Avatar
yeah. my car has been doing the same thing. it boggs down to like 400 rpms and then revs up to 1000 rmp. thrn back down agian......
what could cause this. the car has been sitting for 5 weeks. but i go out and start it up about 2 or 3 time a week???
Old Nov 29, 2009 | 05:51 PM
mobeoner's Avatar
a vacuum lines maybe?
trustdestruction
10
Dec 17, 2008 03:52 PM
mynameizstitch
Aug 17, 2008 04:35 AM
akomplice
Sep 23, 2007 12:44 PM
Chris93Si
Jun 5, 2004 02:24 PM
Dancing is Forbidden
Feb 10, 2003 03:38 PM
