Suspension & Brakes Theory, alignment, spring rates....
WHAT SETUP SHOULD I GET????
Old Nov 26, 2009 | 04:30 PM
phelpsj2's Avatar
Default WHAT SETUP SHOULD I GET????
I have a 97 honda civic coupe. It only has a d16y5 motor but there will be a swap in the futture but not anytime soon. I have been debating on which suspension setup to get for a long time. Its a daily driver, but mostly spirit driving. In the future there might be some autocross but not too much. I want a decent suspension, Not one thats ****, but not top of the line. My price range is 900ish and belowish. I want the car to sit lower and have alil it of a stiffer suspension for better handling, but i also dont want it to ride like ****, comfort is an issue too. so what is the best value for handling, comfort and price???
Old Nov 26, 2009 | 04:34 PM
racebum's Avatar
Default Re: WHAT SETUP SHOULD I GET????
this will probably be a 90% vote for koni/gc @ $799 shipped from thmotorsports.com
now you just have to figure out what spring rates you want to use.
Old Nov 26, 2009 | 08:51 PM
phelpsj2's Avatar
Yathats what i was thinkin about getting. what spring rates are recomended? I dont want it to hard that its a uncomfortable ide, but i dont want it to soft where its not much different than stock. How is 350F/300R
Old Nov 26, 2009 | 08:57 PM
dandaman15's Avatar
Community Builder
It depends on how low you want to go. I think thats fine for 1-2 finger gap but anything lower you want a little stiffer like 400/350.
Old Nov 27, 2009 | 06:24 AM
phelpsj2's Avatar
ya i dont want it slammed, just like a 2 inch drop at max. Probably around a finger between the fender and tire. i should not need a camber kit right? Also i dont know much about the top hats. I heard to go with only the front. Whats some recomendations
Old Nov 27, 2009 | 07:43 AM
dandaman15's Avatar
Community Builder
I dont think you will need the top hats if your only going 1 finger between fender and tire. If you live in an area with bad roads you may want to think about it but its not necessary. You will not need a camber kit but make sure to get an alignment and set the toe to 0
Old Nov 30, 2009 | 09:33 AM
phelpsj2's Avatar
ok so what exactly will i need to buy. The GC sleeves, koni shocks, top hats for the front. Is there anything else i should consider?
Potential2nr
Suspension & Brakes
22
Jan 9, 2012 12:32 PM
RuCkUs24
Suspension & Brakes
16
Mar 6, 2011 06:45 AM
Accord34legacy
Aug 31, 2010 08:25 AM
94-integra-ls
Suspension & Brakes
Nov 17, 2009 06:19 PM
vti444
12
Nov 10, 2003 11:14 AM
