What Clutch should i run?
Old Nov 26, 2009 | 12:41 PM
mytj2000's Avatar
Default What Clutch should i run?
I have a 92 DA with stock B18A1, log manifold, T3/TO4E turbo, RC440's, 2 1/2in exhaust all the way through. Need a clutch before I get it dyno tuned, what clutch would you guys recomend without breaking the bank. I'm shooting for about 275 to 300hp, think my set up will come close? running Crome , stock map, think 10-11psi will make my goal? if not what map sensor would be the best to use to up the boost?
Old Nov 26, 2009 | 12:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What Clutch should i run?
wtq is the number you should be worried about.
act hd ss.
cm stage 4.
2 i have had luck with
Old Nov 26, 2009 | 12:56 PM
boostedEF91's Avatar
your going to go bigger eventually.. so buy one and get it over with. you can either go with a ACT extreme with a 6 or 4 puck sprung.. or for a cheaper price you can buy a competition stage 5 clutch. with a 4 or 6 puck sprung... i'm at 460 and still not slipping. should be good till about 550hp.
Old Nov 26, 2009 | 01:00 PM
www.go-autoworks.com sells the comp clutch for$315.. although for more money you can get the heavier pressure plate but you wont need that.. its around 100dollars more but for what you are going for you will be fine.
Old Nov 26, 2009 | 01:24 PM
intense4thgen's Avatar
the act HD 6 puck is rated for 320trq and its not to agressive for a daily ive also had really good luck with the exedy stage 2 (thick disk on a 423whp set up) 1.5 years and no sliping yet
Old Nov 26, 2009 | 08:21 PM
mytj2000's Avatar
Thanks for the info guys, this is my daily driver so I'm not going after real big numbers just something that is fast.
Old Nov 27, 2009 | 03:43 PM
EFPhilly's Avatar
just like everyone said act 6 puck sprung for DD
Freemananana
Transmission & Drivetrain
Jul 7, 2014 08:33 AM
Basilias
May 25, 2010 12:34 PM
pjr710
Jul 23, 2008 09:53 AM
iwanttogofast
Feb 26, 2007 07:34 PM
streetlvlhatch
Jan 14, 2004 07:47 PM
