FL 1993 240SX coupe for sale SR20DET
Lowered Price need to move this car $5500.00
Tallahassee
Here are the details,
I can be reached at cisco6509@comcast.net if you have any questions.
For more photos click here http://www.wallerweb.com/240sx/
1993 240sx, Coupe Black paint is in great shape. Always garaged.
120k on chassis, 10k miles over 6 years on imported engine & tranny
Ice cold A/C.
Engine Bay
S13 Blacktop SR20DET from Heavy Throttle
S13 ===>> S13 Wiring Service done by Heavy Throttle
Hoses, Seals, etc. from Heavy Throttle
ICE COLD A/C yes it does have A/C that works!
HKS rocker arm stoppers
C&R Racing Dual Pass Radiator with SPAL HIGH CFM DUAL FANs.
Custom Aluminum coolant overflow tank
Enjuku Racing radiator block off plate channels air thru the radiator
Enjuku Racing Cold pipe
Greddy Oil Pan
Greddy oil filter relocation kit.
Moroso Oil Catch Tank
NISMO Motor Mounts
HKS Type S FMIC
NRG Hot Pipe
HKS SSBOV
SS Autochrome Stainless Manifold
stock turbo
Greddy Style SS Turbo Elbow
300ZX TT O2 sensor
Project Silvia 3" Down Pipe
Project Silvia 3" SS Test Pipe
Blitz NUR Spec R Exhaust "expensive"
Transmission / Diff
NISMO Shift ****
SPEC Stage 3, 4 puck Clutch from Heavy Throttle
Stainless Steel Clutch Line
B&M Short Throw shifter
1990 300zx LSD
1993 J30 Axles
Fuel and electrical
Walbro 255 lph Fuel Pump with power lead directly off battery.
Battery Relocation Kit
Optima Battery
High Gauge welding wire positive battery lead to starter
Brakes and suspension
Rebuilt Calipers on all four corners
New rotors drilled all around
Q45 Brake Upgrade
KYB AGX Adjustable Shocks
KYB Strut Mount Insulators
Eibach Pro-kit Springs
Greg Dupree Aluminum Subframe Spacers
Whiteline LCA Poly Bushings
Whiteline TC Rod Bushings
Interior and Gauges
JDM 180Km/h Gauge Cluster re-calibrated to MPH
Autometer Cobalt Electronic Gauges, Oil pressure, Boost and Water temp
Custom Gauge plate for Gauges
Dakota Digital PAC2000 automatic fan controller with digital Temp readout.
Greddy Profec B Spec 2 Boost Controller
Wheels and Tires
5Zigen FN01R-C 17x8 fronts 17x9 Rears Falken Azenis tires 225/45/17 front 245/40/17 rear
BFGoodrich G-force T/A Drag Radials, 225-50-15 on mustang rims
Tallahassee
Ice cold A/C.
Engine Bay
Greddy Oil Pan
NISMO Motor Mounts
HKS Type S FMIC
NRG Hot Pipe
HKS SSBOV
stock turbo
300ZX TT O2 sensor
Transmission / Diff
NISMO Shift ****
1990 300zx LSD
1993 J30 Axles
Fuel and electrical
Optima Battery
Q45 Brake Upgrade
Interior and Gauges
Wheels and Tires
geoinvesting
Honda Civic (2001 - 2005)
16
Jul 11, 2007 09:44 AM
ctownintegra
May 14, 2006 06:38 PM
1993, 2009, 240sx, california, car, classified, comcastnetyahoocom, coupe, fl, florida, mid, nissan, sale, silvia, site, sr20det, tallahassee, west
