Fidanza flywheel ring gear issue
Old Nov 25, 2009 | 12:44 PM
damonk's Avatar
Default Fidanza flywheel ring gear issue
just swapped out my usdm engine with a jdm and noticed some play side to side on the ring gear of my 8.5lb fidanza fly wheel. it doesn't seem to slip. car seems to run fine...
according to fidanza they said if the engine over heats or gets too hot, it can cause the ring gear and flywheel to separate due to the heat expansion... before the engine was swapped, it never really overheated.
without a rattle from the flywheel how pressing do you think this problem is and has this happened to anyone else? I read a few posts on the ring gears being installed backwards but this is a bit different...
Old Nov 25, 2009 | 03:07 PM
filip's Avatar
Default Re: Fidanza flywheel ring gear issue
if Fidanza says that is normal, i think -> dont care
Old Nov 25, 2009 | 03:08 PM
flyrod's Avatar
That expansion excuse doesn't sound right. Aluminum expands more than steel when warmed up, so that ring gear would get tighter.
In answer to your question, what is keeping the ring gear in place? If it can't come all the way off it will probably be ok for a while, but if it's moving around it will only wear against the aluminum and get looser.
Old Nov 26, 2009 | 12:31 PM
nus_dogg's Avatar
Thats quite odd. Mine doesn't move side to side at all. I would feel unsafe at this point.
Prelude Prince
Transmission & Drivetrain
Dec 8, 2016 10:05 PM
crxjarred
Jul 12, 2014 01:21 AM
police vehicle tech
21
Nov 15, 2009 08:12 AM
thewrai6th
Nov 3, 2009 06:09 PM
zman
Nov 16, 2005 04:37 AM
