90 accord ex idle problems
I will try to keep this short. I would really appreciate any help you could give. I have tried to search for this but can't find anything on it. I have a 1990 accord ex with a F22A1 engine with an auto transmission in it. It shows 225K on the clock and had an engine swap (the whole K clip I belirve it's called) before i bought it. It has several problems but the one i can't seem to live with is that it always wants to idle up (grab the throttle )when I am slowing down for a light or stop sign...it will sit at a stop light at a fast idle until i put it in neutral...if i put the tranny in neutral it will rev up to around 2k then idle down again to where it should be(even when back in drive)until i step on the gas again when I have to go through the whole thing again.
Any ideas TIA
Any ideas TIA
I have the same probem and was told it was the TPS Sensor. This sensor is on the throttle body and is a PITA to get off. Do a search on this and there are many threads on how to get it off. You may try that or try cleaning your TB and IAC valve..GL.
hondamtrco4life
Jan 5, 2008 03:59 PM
