Suspension & Brakes Theory, alignment, spring rates....
which camber kit?
Old Nov 25, 2009 | 06:37 AM
hialeahzbg's Avatar
Default which camber kit?
just got my new koni's and i need a camber kit so the car can get aligned.... ive been researching some and i hear the sk2 camber kits dent the shock tower and the ingalls kit gets loose from time to time...what do you guys recommend?
Old Nov 25, 2009 | 08:27 AM
Moosecakes's Avatar
Default Re: which camber kit?
if you check the stickies you don't really need a camber kit.. if they tell you they can't align a car without them they suck.. you don't use camber kits when aligning the toe...
Also how low are you going? I'm ****ing dumped and I have only hit my shock towers once with s2's however I think that's going to chance today since i went lower but whatever lol. If you aren't going super slammed you won't have to worry about it smacking the strut tower. It's also going to depend on your spring rates if you hit them or not.. s2's get my vote.
Old Nov 25, 2009 | 12:11 PM
hialeahzbg's Avatar
well i live in miami fl and the streets are worse than the rocky mountains... my fender is a little lower than the tire..i tuck the tires without me sitting in the car...my mudflap is like 2 fingers from the ground...so if i go get it aligned and they said i need a camber kit they dont know what they are talking about?
Old Nov 25, 2009 | 01:43 PM
TunerN00b's Avatar
Correct.
With the car that low, you really don't want to kill what little front suspension travel you have left with a camber kit.
The car came stock with the ability to adjust the toe, which is all that is needed to align the car.
v8 killer
Honda Civic (2006 - 2015)
Mar 9, 2012 04:02 PM
siguy9900
16
May 13, 2008 07:05 PM
JRTegman987
Suspension & Brakes
Oct 22, 2006 11:38 PM
casmello
Jan 3, 2006 04:12 PM
