TOP Mount or Ram Horn Manifold for 500+HP D16????
Wow. Both. You can make 500+hp on a log mani if your boost is high enough. It's really about where you make the power at that point. If you are going for higher rpm's, the ram is the most logical choice.
not quite, the top mount will give you your power goal easier.. depending on your setup.. with a top mount your power will come on later and you'll most likely have to rev higher to get the output that a ramhorn wwould give at a lower rpm.. also depends what turbo your mounting on this car. smaller turbos die out quicker so they wont make the power you want at a high rpm.. so basically you could choose either just put together the right setup and you'll be fine..
Either will work fine. I make about 500 on a log manifold. Your manifold wont make a huge power difference, just buy good quality. A top mount will give you more room for your down pipe with a large turbo
A ram horn vs. a log manifold will make a ton of difference.
As to the original poster, see what your setup looks like. I'd suggest a ram horn, a top mount will take longer to spool up, you can make just as much power on a ram horn then a top mount.
x2 on the ramhorn vs the log.. evans did a test with full race and made 50whp more with a ramhorn than a log at same boost level.. ramhorn with a nice size turbo and you'll be on your way to 500hp..
not even. topmount became a bandwagon because honda tech loves bandwagons. you can fit a very large turbo and a 4" DP on a ramhorn just as easily as a top mount. the only reason i would choose a topmount over a ramhorn is if i was running a divided housing turbo.
My setup:
D16Z6 block
Balanced and micropolish crankshaft
Eagle rods
CP pistons 9:0:1 75mm
Golden eagle block guard
ARP Head Studs
Cometic Head gasket
D16Z6 Head Port and polish
SuperTech Spring and retainers
AEM camgear
Stock camshaft
Port and polish Y8 Intake manifold with 62mm TB
AEM fuel rail
Precision Turbo 880cc injector
Precision Turbocharger SC6262 Billet 70a/r cold 63a/r hot
Walbro 255 fuel pump
OBX LSD
ACT Xtreme Clutch kit
Tial wastegate 38mm
Tial Blow off
2.5 intercooler piping
31x12x3 intercooler
P28 ECU with Crome program
With this setup, which of the two manifold would work best for me to get to 500hp, Thanks
D16Z6 block
Eagle rods
ARP Head Studs
Cometic Head gasket
AEM camgear
Stock camshaft
AEM fuel rail
OBX LSD
Tial wastegate 38mm
Tial Blow off
31x12x3 intercooler
you most likely are going to need a 44mm wastegate.. with the turbo you are using there is going to be boosted creep. and if you are trying for 500 hp. that wastegate isnt going to hold the pressure you are going to be at... go with a ramhorn manifold.
Really?? 40whp?? Man this sucks. Im right in the middle of my new build and I'm not sure I can afford a new manifold before my tune. Ive got 2 weeks. My **** is fully sleeved and I want the best! I can afford a manifold but I'd need a DP and a dump tube...
Hit up RCAutoworks they have some really nice stuff and there prices are the best I have seen
http://cgi.ebay.com/ebaymotors/Civic...Q5fAccessories
This manifold will be good? In terms of quality and shape of the manifold.
Because if you look the four tubes are not the same distance. Friends are saying??
