Suspension & Brakes Theory, alignment, spring rates....
ball joints
Old Nov 24, 2009 | 10:14 PM
'00DC2's Avatar
Default ball joints
just wanted to know which ball joint is the load carrying ball joint on a 2000 integra gsr. is it the upper or lower? i always thought it was the lower but i heard it could be the upper one..
Old Nov 25, 2009 | 10:33 AM
TunerN00b's Avatar
Default Re: ball joints
The lower one. The LCA has the spring and shock assembly attached to it, hence it carries the weight. The upper ball joint simply holds the knuckle in place in regards to camber.
Old Dec 1, 2009 | 05:37 PM
tlchkc's Avatar
If this ball joint is damaged would the front be a little bumpy?
Old Dec 1, 2009 | 05:51 PM
TunerN00b's Avatar
Driving on any damaged ball joint is bad, and likely to produce issues driving the car. Bumpy, uncontrollable, random steering, wandering back and forth, and many other symptoms, can all be caused by a bad ball joint.
The wheel is held to the hub by 4 (or 5 for some) bolts, while the knuckle is held with only 2 ball joints. You can lose a lug and be ok (debatable), because there are at least 3 more still there, but if a ball joint goes...
Old Dec 2, 2009 | 01:08 AM
'00DC2's Avatar
when i move the wheel left to right quickly at a complete stop i hear a light clunk sound. could this be a loose/worn ball joint? does your teg make this noise too? the boots arent ripped but the damage can be internal, right? also my car has excessive neg. camber, i think somethings bent (lower ball joint)..HELP!
Old Dec 2, 2009 | 01:50 PM
Dang EG's Avatar
It could be a bad axle as well... The axle could be damaged without the boot be torn. I had the same issue, crazy negative camber and clunking as I moved the wheel or just driving in a straight line. Double check all moving parts as well... GL
Old Dec 2, 2009 | 05:24 PM
'00DC2's Avatar
huh, never thought about the axles being bad..how can i check these? my old setup was skunk2 springs and skunk2 shocks. the shocks have a shorter body than oem style shocks, so my car was too low in the front. the ride was horrible too. i recently switched to koni street shock, and neuspeed race springs. the ride got better, but it looks like the shorter shock f*cked something up. my front camber is -2.2L -2.4R, rear camber is in spec. i was suspecting lower ball joints, but now am not sure..damn you skunk2!! also when i look at cars that are lower than mines there front wheel camber is more positive than mines, and they're not running any camber kits, so i know something must be bent.
derrack
Suspension & Brakes
Jan 23, 2017 03:11 PM
MechEng
Aug 9, 2011 02:13 PM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
russianswty
Feb 18, 2007 02:24 PM
snatch
25
Jul 13, 2005 04:54 PM
