Drivers door wont unlock????
Old Nov 24, 2009 | 10:51 AM
Bob Dole!'s Avatar
Default Drivers door wont unlock????
I'm stumped! The drivers side door on my del sol just will not unlock from the inside or outside. Has anyone had this problem before? What did you do to fix it?
Old Nov 24, 2009 | 12:00 PM
90Rexx's Avatar
Default Re: Drivers door wont unlock????
common... most likely your prop rod has detached, or your door latch requires replacement or adjustment.. start by pulling the door panel and verifying all prop rods are connected, if they are you will need to pull the door latch off and see if you can lube/adjust it, if not it will need to be replaced
Old Nov 24, 2009 | 12:04 PM
trustdestruction's Avatar
Sounds like a seized door latch. If you ever get it open, soak the latch mechanism in WD-40 or some Silicone Lubricant Spray, it worked quite nicely for me.
Old Nov 24, 2009 | 10:42 PM
Bob Dole!'s Avatar
So i pulled the drivers door panel and the lock rod is just stuck. It won't move in either direction. So how exactly do i get the door handle off?
Old Nov 25, 2009 | 10:02 AM
Bob Dole!'s Avatar
Bump! I want to open my door!
Old Nov 25, 2009 | 11:50 AM
90Rexx's Avatar
not the handle, the latch.... should be held on by 3 brass looking bolts.. its kinda a PITA to get out lol.
soak it in wd40 for a while lol
Old Nov 25, 2009 | 01:12 PM
Vindicator9000's Avatar
318 Curves, 11 miles
It is kind of a PITA to get out, but doable.
Does the car have power locks? I had this problem on mine, and thought it was the latch, so I junkyarded one. Come to figure out that there was nothing wrong with the latch, but the power door motor had seized up, which was preventing the locker on the latch to move.
Back to the junkyard, picked up a power lock motor. Total expenditure for both was about $11.
The power lock motor is the little plastic doohickey that is attached to the latch with some ganky looking screws.
nateb22
May 6, 2009 11:00 PM
Tarlacon
Dec 14, 2008 03:54 AM
Frost7177
Oct 27, 2008 01:31 PM
97itr86
Dec 31, 2004 02:06 PM
4drEF
Sep 7, 2004 01:32 PM
