Rear door will not open from outside after alarm install
1998 Honda Civic Sedan
My passenger rear door will not open from the outside, only inside handle opens it even though the door button is up. When I use the outside handle, it feels like it is not attached to any linkage, but has normal tension just like if it was locked.
Maybe coincidence, but this happened after i installed an alarm.
Thanks for any help.
Def. a coincidence. remove the door panel and inspect whats going on. The plactic lever on the exterior door handle probably broke off leaving the rod that connects the exterior door handle to the door latch dangling. If so, you will need a new exterior door handle.
condor22
Jan 23, 2019 09:16 AM
