Suspension bump stop question!
Old Nov 23, 2009 | 07:34 PM
xJaccord00x's Avatar
Default Suspension bump stop question!
Is it necessary to cut the front stock bump stops when using lowering springs? Will it be a big problem or issue if I dont?
Old Nov 23, 2009 | 10:40 PM
Bwill9886's Avatar
Default Re: Suspension bump stop question!
It is HIGHLY recommended you reuse the bump stops or get new ones, as the results of not having them when they are needed are less than ideal...
It depends a lot on your drop. If you are dropped more than an inch (that may be being a bit conservative) then I'd definitely cut them a bit. No need to take chances.
Old Nov 24, 2009 | 10:53 AM
19Accord97's Avatar
I cut mine in half for a ~2.5 in drop
Old Nov 24, 2009 | 11:44 AM
Atreidies's Avatar
You don't HAVE to cut them, but if you don't, you lose suspension travel. If you are slammed, you need to cut them so you are not riding on them. Just don't cut them so much that the frame hits the ground when you bottom out.
Old Nov 24, 2009 | 12:14 PM
driftin4's Avatar
Follow the lowering spring manufacturers guidelines for your car!
Old Nov 26, 2009 | 04:46 PM
Bwill9886's Avatar
The best suggestion.
Old Nov 26, 2009 | 04:55 PM
Farrukh's Avatar
idk what kind of kit ur using but if its a cheap one lets say off of ebay then those dont work, the spring size and spring rate are too low and is too small, and i wouldnt recommend using lowering springs with stock shocks, and in my opinion, riding the car anywhere near the bump stop is a big no-no for me. cuz ur losing most the shock travel that dampens the bump. If u hit a hard one, the bump stop will only do so much untill something else gives.
Old Nov 30, 2009 | 02:09 PM
Thanks for all your repsonse! Im riding on tokico blues and tein s tech springs by the way. I will cut the bump stops when I have the time. Would cutting them to spec also make the ride less bounceing?
Old Dec 1, 2009 | 10:30 PM
Bwill9886's Avatar
No, that should not affect the bouncing you are experiencing.
That boucing is most likely due to using tokico blues (which are basically stock replacements) with springs that lower your ride height a pretty good amount. The shocks just aren't meant for that kind of drop, and so don't perform like they should.
itrdave
Feb 9, 2022 10:16 AM
Kidnkorner
Suspension & Brakes
Mar 9, 2010 06:59 PM
lilced03
Honda Civic (2006 - 2015)
Mar 21, 2008 09:43 AM
Tam N
Feb 14, 2007 04:13 AM
Tyson
Dec 25, 2005 04:40 PM
