RACE CAR PART OUT!
time to move on. i am selling this car as a rolling chassis or parting it out. each item has its price or will sell as a whole rolling chassis.
lets start with the chassis. it is a 93 integra mild steel chassis. built to sfi spec as far as tubing size and placement of tubes. 024 steel tin work floor and firewall. the rear tin work is .032 alumn. the chassis alone will come with only the following, but other parts can be added for an additional cost. the chassis ONLY includes seat belt 5 point. mounting for any kirkey alumn seat. fiberglass one piece front end that is unfinished. steering column gas pedal all lexan throttle cable and alumn. dash. will be asking 2000 for that
fiberglass doors made by mb products. exact replica of a factory door. 600$
custom straight axle with american racing track star 15x3.5 black rims with 24.5 tires, qa1 coilover shocks with 150lb spring, willwood single piston calipers with wilwood .310 rotor and hat. comes complete with the 3 link ataching points all with heim joints. 1800$
complete front suspension including lcas. these are macpherson struts with qa1 450lb springs custom top hats with needle bearings. the knuckle is also custom with wilwood dynalite 4piston calipers and stainless brake lines. the lower control arm is custom with heim joint atachment points. the steering rack will also be included with this due to the custom tie rod end setup. 1000$
pics of the front suspension will be up soon forgot to take the pics..
i will sell the entire rolling chassis with everything included above for 5000$ all you will need is your own engine, electronics, and seat. make me some offers id like to have this gone.... dont hesitate to ask any questions. thanks
NOT INCLUDED IN SALE OF CAR! a set of webber 55dco side draft carbs with custom intake, throttle linkage, and earls fuel fitings. this is for the h22 engine. 1500$
racinjason
Aug 2, 2007 03:21 PM
racinjason
Aug 2, 2007 01:13 PM
