b20b does not rev pass 1000
Hello HT member i have a b20b in my 95 honda civic. the problem is that my engine does not rev pass 1000. i spoke to a mech and said that it could be etheir my MAP or TPS. now i know some b20b have a crank sensor for the obd2 modle, but my engine not have it, could that be the problem as well?
the reason i put it in the hybrid section is becaues my b20b has a b16a intake mainfold and it has a GSR aftermarket throttle bodie with the b20b MAP sensor and TPS, and the idle air control valve. And i have a obd1 chip Ecu for the b20b.
NOTE: the mech told me that some obd2 engine have their own timing sensor?
Update: today i start the car and i took off the idle air control valve while the car was runing, all of a sudden the car dies. could that be that my iavc doesnt work?
what do you HT members think?
Update: does it make a difference if the idle air contro valve is obd2. the reason i say this; becaues my engine harness is obd1 and the idle air contro valve have a different volt or responce. plus i think my friend gave me a old o2 sensor.
so what im going to do is buy: ls obd1 o2 sensor, sprak plugs and spark plug wires,and a disturiter rotor. hope this makes a difference.
wish me luck..lol.
update: I rev it up it wont go past 3000 rpms?... what could be the problem?... When i tried to obtain the check engine codes the check engine light just stays on and does not blink. What is causing this.
Update: i have found the problem. i tested the ECU on my friends Honda and it did the same thing, it wouldn't rev pass 3000 rpms. the computer was giving him the same problem.
New topic: The car idles fine and it revs fine, but when i leave the car running it turn off by it self.
Update after three years: At the end of this battle i had found the problem, it was my computer that was not working because it was a chipped po5 for and ls (thats what the guy told me when i bought it) and my distributor was also the problem. the cell code was 8, 40, and 10 i cant remember. i had bought a new distributor and purchase new internals like the coil and the ignitor that was causing all the problems. well good luck people. it was nice working with my Honda hope this helps you out in the future.
wish me luck..lol.
Last edited by EGR95; Oct 15, 2012 at 09:45 AM. Reason: I still have one problem...
well today the mech saw the car, and said the engine was not out of time. the mech only told me that it could be my wiring.
NOTE: i did a wire tuck on my car so i don't know if i put something incorrect. i have not yet check if i switch the MAP sensor and the TPS sensor, but i will check.
what else could it be?... or should i just let the mech diagnose the car to see the problem and pay $50?
If all your plugs are in the right place, I would start going through your wiring and make sure nothing is grounding out. Maybe you scraped a wire and it's grounding or some wires are crossed. It will be something silly, it always is.
Post some pics of the bay, the tuck, etc..
. who knows you might be right.
update: today i start the car and i took off the idle air control valve while the car was run, all of a sudden the car dies. could that be that my iavc doesnt work?
update: does it make a difference if the idle air contro valve is obd2. the reason i say this; becaues my engine harness is obd1. plus i think my friend gave me a old o2 sensor.
so what im going to do is buy: ls obd1 o2 sensor, and see if that makes a change.
my rpm sensor?... i have not check.
update: i put the everything new and it still does the same thing.
my engine taps out at 3k and no more?
, but what i did, i went to check my friends harness and i compared colors and they were the same.Update: i rev it up it wont go past 3000rpms?... what could be the problem? when i tried to get the check engine code the check engine light just stays on and does not blink. what is causing this?...
No. Have you jumpered the service check connector to check for codes? If you have, and all you get is a solid check engine light, then it's a problem with ECU (or the chip inside). Have you ever run this ECU with that chip before?
If it was a problem with the distributor, or some other sensor, you'd get some codes from jumpering the service check connector.
