Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Problems starting- HELP!!!!
Old Nov 23, 2009 | 09:21 AM
john12brd56401's Avatar
Default Problems starting- HELP!!!!
I have a 1990 acura legend, 2.7, v6
There was a hole in the fuel line that rusted open and the car was spouting gas outta the open line- now that i have patched the hole in the line by replacing the rusted chunk with rubber hose, the car will not start- i have gas all the way to the motor, i have checked several times- and i know the fuel pump is working- could there be air in the fuel rails or something preventing the car from strting???
Old Nov 24, 2009 | 06:31 PM
slomofo's Avatar
GDD Member
Default Re: Problems starting- HELP!!!!
Are you getting spark? Did the car run before you patched that line?
Old Nov 27, 2009 | 01:30 AM
YeuEmMaiMai's Avatar
this is what you do
to make sure all the bubbles are out
turn car on and off about 10 times (turn on until you hear the pump go buurr and stop and then turn car off, repeat 9 more times.
if you do not hear the fuel pump, check main relay (boy were those a giant pos) you can repair them by resoldering all the joints on the PCB.
Old Nov 27, 2009 | 01:27 PM
skaternak's Avatar
make sure you have proper fuel pressure. because you replaced metal with rubber
Old Nov 30, 2009 | 08:26 AM
thank you to all your suggestions- i will try things and see what i can uncover
Mr. Prelude
May 21, 2011 07:27 PM
jdmtp7
Aug 13, 2008 05:24 PM
deerek101
Aug 31, 2007 08:53 AM
4gCRX
Sep 30, 2004 04:42 PM
pr0digy1
May 12, 2002 06:17 PM
