GSR Ticking after instaling ITR replica cam
Old Nov 22, 2009 | 09:54 PM
seri_gsr's Avatar
Default GSR Ticking after instaling ITR replica cam
Recently i bought a brand new 00 spec ITR intake cam(same as CTR cam) localy and when i had it installed i had to put the dizzy all the way back to get the timing right... so i figured it was Chinese knock off... and my engine started ticking realy loud even tho i had the valve adjustment done when i instaled the cam... and tht day i had my friend over so he cud tune it... so we drove it out to do the street tune and first pull we did(pulled realy strong) it started tickin louder, then we did it again and it double thicking... and did it once more and it started triple thicking... so we said screw it and drove it bak
wat cud it be? lma's? valve hitting the piston?
its a 01 gsr with stock exhaust cam, gsr dual valve springs on exhaust installed and i have skunk2 mani and 4-1 headers, i just rebuild my motor 500 miles ago
Old Nov 22, 2009 | 09:58 PM
racebum's Avatar
Default Re: GSR Ticking after instaling ITR replica cam
check the lash again now that you've driven it. could be on the loose side. also, post this in the all motor forum. the engine education level is higher there than in here.
Old Nov 22, 2009 | 10:27 PM
seri_gsr's Avatar
oh alright thanx will do
Old Nov 24, 2009 | 08:30 PM
671darren's Avatar
Lost motion assemblies get loud after age, and even after installing larger cams.
kaleb.honda.si
Sep 8, 2015 11:59 AM
seri_gsr
23
Nov 25, 2009 09:51 PM
stnwag0n
Oct 30, 2002 03:08 AM
AznInvasion
Sep 14, 2002 09:41 PM
1fastGSR
Sep 7, 2001 08:12 AM
