question to anyone who has re built a ys1
Old Nov 22, 2009 | 10:07 AM
gearheadcurt's Avatar
Default question to anyone who has re built a ys1
when you go to put the trans case back to one peice does it need a little bit of force or not?
I beleive the main bearing at the top of the tower isnt going in with ease
and tips?
Old Nov 22, 2009 | 12:59 PM
95 integra's Avatar
Default Re: question to anyone who has re built a ys1
Wiggle it, make sure your snap ring is expanded...and dont force it too badly as you'll crack the case (like I did). Usually beat on it a bit with a rubber hammer it and helps alot too.
Old Nov 22, 2009 | 01:24 PM
Dogginator's Avatar
Daisy... Daisy...
How large os the gap? Make sure part 11 is indexed properly.
Old Nov 22, 2009 | 08:34 PM
it hasnt even gotten to the snap ring at that point, it's close though
part 11 is correct
the gap between the cases when it stops? not even an inch
Old Nov 23, 2009 | 02:33 AM
Dogginator's Avatar
Daisy... Daisy...
I recall much wiggling. IIRC, the shift rods were an issue.
Old Nov 23, 2009 | 10:44 AM
theunknowntech's Avatar
New User
and tips?
It does not need any force at all, other than the force of gravity. Turn it upside down.
This is assuming that you have used lock ring pliers to free the lock ring so that it can slide into the bearing groove, of course.
Go easy on the sealant re-application, it doesn't (and shouldn't) take much.
JDMCRX
Welding / Fabrication
49
Nov 22, 2006 05:25 PM
i-VTEC_do_you
Sep 8, 2006 04:48 PM
b16ahybrid
Nov 28, 2005 07:31 PM
DvSrOmE
Nov 3, 2002 05:37 PM
