Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Valve adjustment question..
Old Nov 22, 2009 | 07:43 AM
redb16coupe's Avatar
Default Valve adjustment question..
can valve adjusment cause overheating, my car has a slight miss on idle and i think its from an improper valve adjustment i did by not knowing the correct clearences..
1. can someone provide me the correct clearances i have a d17a2
2. is it possible?
my car overheats after about 30-50 min of highway driving.
Parts changed
radiator, cap, thermostat.
i also bypassed the heatercore, and the iacv coolant lines thinking it might of had a slow leak.
i would really appreciate the help
Old Nov 22, 2009 | 01:06 PM
It Wasn't Me's Avatar
Default Re: Valve adjustment question..
1. Search + "valve lash" = https://honda-tech.com/forums/honda-civic-2001-2005-78/searched-vtec-crossover-01-ex-2622813/
2. I wouldn't think this is the cause of the problem.
Old Nov 22, 2009 | 07:50 PM
bomerman19's Avatar
no. And sounds like the head gasket has gone and it is pushing air into the system.
Old Nov 23, 2009 | 01:24 AM
theineffable's Avatar
How did you manage to do a valve adjustment without knowing the clearance specs?
check the stickers in the engine bay. it might list the valve specs. i know my s2000 has it on the hood
Old May 22, 2010 | 09:42 AM
purple's Avatar
Im doing a valve adjustment right now, actually. How do you know which valves are intake/exhaust? I have an 01 Honda Civic EX 1.7L A/T
Old May 22, 2010 | 04:34 PM
ones at the front of the car are exhaust. note which side of the engine the exhaust pipes go to...
Old May 22, 2010 | 05:59 PM
lzyga09's Avatar
i never heard of a car overheating because the valves are out of spec. look at the color of your coolant and when is the last time you checked your oil?
Old May 24, 2010 | 01:43 PM
b0yg0tskills's Avatar
the size should be on the sticker under your hood. so pop it open and look for the sticker. and possible of over heat from head gasket.
dano88
Aug 17, 2009 08:35 AM
pr3lude1992
Apr 1, 2009 05:33 AM
eliasromero
Mar 12, 2007 08:37 PM
redpeppers
Jul 26, 2005 02:33 PM
