1998 and 2003 Accord V6 timing belt change
Old Nov 22, 2009 | 05:50 AM
stevescivic's Avatar
Default 1998 and 2003 Accord V6 timing belt change
Hi HT members,
I have 2 friends asking me to replace their timing belt on their 1998 and 2003 Accord V6s.
I've never worked on the 3.0 Accord engine before and I just wanted to know how similar it would be to changing a t-belt on a 2002 3.5 litre v6 Honda Odeyssey minivan?
Seems fairly straightforward to me but I just wanted to make sure that I am not taking on a job that I might not be able to properly finish.
Couple things worth noting:
1. I do have the factory honda crank pulley holder tool that has so far worked on every Honda with a hex cutout in the crank pulley.
2. I have a Honda tensioner shaft holder pin
3. I have a vise (to compress the tensioner)
4. I have plenty of experience working on Honda 4cyl engines (I think I've done about 50 t-belts now...)
5. I do have a spare threaded battery bracket hold shaft/hook/holder/whatever its called to screw into the tension pulley to hold it up for the installation of the new t-belt.
Based on my memory of the v6 odyssey engine I'm assuming that its very similar if not identical replacement procedures.
Am I correct in my thinking so far?
Thanks
Old Nov 23, 2009 | 03:24 AM
hondamark35's Avatar
Default Re: 1998 and 2003 Accord V6 timing belt change
there may be some minor differences between a t-belt job on an Odeyssey and one on an accord V6 mostly related to the differences in the two chassis, but if you've done one you can do the other.
SystemKhaos
Apr 30, 2022 06:27 AM
Ella Vaughn
Nov 11, 2015 09:41 AM
MindEddy
Nov 3, 2012 06:39 AM
