B20 ITR with Pro1s..
Old Nov 22, 2009 | 03:35 AM
Naturalasp's Avatar
Default B20 ITR with Pro1s..
Hello everyone,
Ive just recently put this motor together, she made a nice 214whp and ran consistent 13.3 on street tires r888s.
I feel the pro1s make loads of midrange power and not enough up top, ive been thinking to switch to buddyclub 4s. What do you guys think to this switch? Im not bothered about low end or midrange the b20 makes enough torque in those areas as it is, im just looking for raw all out power up top.
Look forward to hearing your views.
Thanks
Old Nov 22, 2009 | 04:35 AM
Garrett's Avatar
Default Re: B20 ITR with Pro1s..
I think pro2 could be the only to have more power
you could take a look at this https://honda-tech.com/forums/all-motor-naturally-aspirated-44/precisionautocanada-com-pro1-vs-pro2-dynotest-2684800/
Old Nov 22, 2009 | 08:07 AM
01-0720's Avatar
yeah definitly get pro2's
and r888's are road race tires, not drag race tires
Old Nov 22, 2009 | 10:55 AM
Do-Work's Avatar
go with the bc4's
Old Nov 22, 2009 | 11:57 AM
Teamdiesel's Avatar
Originally Posted by b20vtec08
go with the bc4's
Why?
Old Nov 22, 2009 | 01:49 PM
Do-Work's Avatar
Originally Posted by Teamdiesel
Why?
cause he said hes looking for more power up top and with the bc4's he will get that
Old Nov 22, 2009 | 02:23 PM
DDTECH's Avatar
Wrong.
Old Nov 22, 2009 | 03:03 PM
SergEK's Avatar
you could take a look at this https://honda-tech.com/forums/showthread.php?t=2684800
Pro 2's
Or call Rocket
Old Nov 22, 2009 | 04:35 PM
Do-Work's Avatar
Originally Posted by ALL M0T0R
Wrong.
how?
Old Nov 22, 2009 | 05:13 PM
DDTECH's Avatar
how?
Realistically, do you think the bc4's will run with the pro2s??
Because they wont, the pro2's provide more mid - top range then the bc4's .. the normal debet would have been pro1 vs bc4's in which the bc4's would have been a better choice.. the bc4's are smaller then the pro2's..
pro2's vs the bc5 is a different story.
Old Nov 23, 2009 | 07:11 AM
Naturalasp's Avatar
Has anyone used rocket cams with a B20? How would the BC5's work with this setup, not enough compression?
Old Nov 23, 2009 | 07:21 AM
92TypeR's Avatar
FSAE
Pro2's or Pro3's.
/thread
Old Nov 23, 2009 | 07:33 AM
koczeka's Avatar
get a 22 from him
Old Nov 23, 2009 | 07:46 AM
DDTECH's Avatar
If you wish to inquire about RM Cams, you may pm me.
Old Nov 24, 2009 | 10:07 AM
Naturalasp's Avatar
Looks like well be going with rocket motorsport, ill keep you guys posted with the results
Old Nov 24, 2009 | 11:06 AM
92TypeR's Avatar
FSAE
What model? M22X's are very much on the same level as Pro1's. Not sure if you will see much of a top end gain like you are looking for.
Pro2's will make more power than M22X.
Old Nov 24, 2009 | 11:46 AM
Naturalasp's Avatar
Im going with the ****'s, spec looks good.
Old Nov 24, 2009 | 11:51 AM
SpEeDyX's Avatar
Originally Posted by 92TypeR
Pro2's or Pro3's.
/thread
^this
Old Nov 24, 2009 | 08:59 PM
rare92gsr's Avatar
Proo....ooo 2 !
Old Nov 24, 2009 | 09:04 PM
nokturnal_munkeeboy's Avatar
pro 2 only again 4hp vs pro 1. i would go wit buddy club spec 4. try them out
Old Nov 25, 2009 | 12:05 AM
oresama's Avatar
I'd say try Buddy ClubSpec 4's, they have longer duration than SK2P2, with less lift....so it seems they would give a smoother power-band, less chance of knocking your pistons (say if your camgear bolts slowly become loose), work with most dual valve springs (Omniman dual valve springs are rated up to 12.5mm lift and are way more affordable thank skunks), and increase overlap which is good for high rpm engines.
Spec 4: Duration = Int:306deg Exh:302deg
Lift = Int: 12.3mm Exh:11.8
SK2P2: Duration = Int: 277deg Exh: 284deg
Lift = Int:13.0mm Exh: 12.4mm
Just my two cents ...by the way this is all theoretical knowledge based on sound reading on cam profiles and timing (don't knock me cause i'm sure who ever designed your cams took this "text based" info into heavy consideration when engineering your cams).
Old Nov 25, 2009 | 02:25 AM
Naturalasp's Avatar
Thanks for the info dude, I feel like buying all 3 cams. I think im going to go with the rockets for now, and then hopefully in spring ill have my dyno and do some tests between the pro2s and bc4's. See which out of the 3 work best
Old Nov 25, 2009 | 02:38 AM
koczeka's Avatar
P1 and m22 are not the same class, m22 is a lot bigger in my book, it is like P2
How do U know for sure P2 would make more then m22?!
Old Nov 25, 2009 | 02:43 AM
koczeka's Avatar
Forget the marketing BS, most cams are light years away from given specs (what only represent a little portion of the whole picture).
Old Nov 25, 2009 | 06:17 AM
92TypeR's Avatar
FSAE
On paper, gross lift over duration and cam profile design. The M22X may have more duration, but the 'area under the curve' between IVO/IVC and EVO/EVC is greater on the Pro2's.
From subjective reasoning and experience, the builds I have done/tuned with M22X's have been good, but Pro2's have been a bit stronger, especially in the low-mid range.
Either cam is a great choice. But I am confident Pro2's will make more power.
