Building 82mm ls/vtec few concerns?
Old Nov 21, 2009 | 09:38 PM
tempsohc's Avatar
Default Building 82mm ls/vtec few concerns?
I have had the b18b block bored out to 82mm and was gonna use rs machines ctr pistons along with a Gsr head. I dont know exactly how the compression calculators(c speed,zeal) are coming up with there compression numbers without knowing the flow characteristics of my motor. To any knowledgeable engine builders what will my compression ratio actually be? I am trying to build around the limits of 92 octane fuel.
Old Nov 21, 2009 | 09:45 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Building 82mm ls/vtec few concerns?
You'd be looking at about 13.2:1, you're not going to want to use those pistons. Use the P30's or Pr3's. You'll probably run into clearance issues with the pistons slapping the head.
https://honda-tech.com/forums/showth...pression+ratio
Old Nov 23, 2009 | 11:44 AM
tempsohc's Avatar
what would the compression be with 82mm p30 pistons?
Old Nov 23, 2009 | 11:51 AM
00Red_SiR's Avatar
All Motor Mentor
http://www.c-speedracing.com/
Old Nov 23, 2009 | 11:57 AM
revhardallday's Avatar
92 octane stay under 12.5:1
and a 82mm on a b18 will not last long you weakend the cylinder wall alot. anything over 81.25mm id recomend sleeve.
Old Nov 23, 2009 | 11:59 AM
00Red_SiR's Avatar
All Motor Mentor
82mm is fine. It's a bad tune that will kill the motor here, or stock rod bolts in an LSv.
Old Nov 24, 2009 | 11:51 AM
tempsohc's Avatar
I was reading somewhere that the cspeed and the zeal autowerks calculators were innacurate.
Old Nov 24, 2009 | 12:22 PM
00Red_SiR's Avatar
All Motor Mentor
only when using CTR/PCT pistons in the calculator is it really off. You're using P30's.
Old Nov 24, 2009 | 12:32 PM
Top Ramen's Avatar
This is really confusing. What do "flow characteristics" have to do with the static compression ratio?
all-mtr-teg's Avatar
Quit repeating what you heard from other inexperienced people.
I'm driving a 81.5mm bore build with over 110k miles and another motor I built for my buddy is running a 82mm bore build with over 75k miles, and our motors are both on stock sleeves.
Old Nov 26, 2009 | 09:10 PM
tempsohc's Avatar
Flow characteristics have nothing to do with static. It has alot to do with dynamic. Why i was asking is what efficiency did they decide to base the static compression on?
Old Nov 27, 2009 | 02:35 AM
92civiceg9gsr's Avatar
CTR pistons should only be used in a B16 because their domes are so high. When they're used in a B18vtec they hurt the flame travel in the cylinder. Basically they divide the combustion chamber in half.
Old Nov 27, 2009 | 07:31 AM
What if it's an LS or B20 vtec with a B16/ITR head? How is that any different than a B16B?
Old Nov 27, 2009 | 08:42 AM
ericracingpr's Avatar
I build a couple of 82 set ups for years daily drive with no issues at all I can say anything over 82 is when u actually need sleeves.
Aro321
Dec 22, 2006 11:43 PM
unix4linux
17
Nov 16, 2005 10:33 AM
pane93civhb
Mar 19, 2005 03:44 PM
streetlvlhatch
Jan 22, 2004 09:55 AM
