Suspension & Brakes Theory, alignment, spring rates....
Cheap Sleeves Good Springs
Old Nov 21, 2009 | 01:37 PM
Teracivic's Avatar
New User
Default Cheap Sleeves Good Springs
Wouldn't a cheap sleeve off ebay with some good springs and shocks be just as good as any other coilover? Sry if its a noob question. Thanks
Old Nov 21, 2009 | 02:02 PM
STOCK_SOHC_DX's Avatar
Default Re: Cheap Sleeves Good Springs
It should be fine but it doesn't cost that much more for a good set, unless you get the springs free.
Old Nov 21, 2009 | 03:50 PM
dandaman15's Avatar
Community Builder
I've heard stories of ebay sleeves, and have seen pics of them cracked in half. However I still would spend $50 for 4 sleeves and get like swift springs or eibach springs, but they are like $70 a piece still. 70*4= 280 + 50 = 330. Ground control set-up = 300
Old Nov 21, 2009 | 05:55 PM
Tyson's Avatar
do the math like the guy above and youll see youre not saving anything.
really tho, there is a difference in GC sleeves. theyre made to fit properly and have a better perch mechanism. just apply a little wd40 or antisieze on the bolt threads to prevent the anodized surface from galling up.
its the anodization that causes people to have issues with the stripped cap screw. same reason why cheap aluminum lugnuts seize often....
Old Nov 21, 2009 | 09:52 PM
Teracivic's Avatar
New User
Thanks thats what I needed to know!
G2_Fella
Suspension & Brakes
48
Aug 23, 2006 07:19 PM
meagainsttheworld
Apr 4, 2006 04:50 PM
Droppedatbirth!
Jul 17, 2004 01:43 AM
NickEroller
29
Jun 17, 2004 01:44 PM
live4speed
Aug 20, 2003 06:32 PM
