Epoxy Primer/Sealer?
Old Nov 21, 2009 | 08:23 AM
boosted.CRX's Avatar
Default Epoxy Primer/Sealer?
Hey guys, I'm starting to collect stuff for my first paint job on my EF and after much research I came up with a question. I want to use epoxy primer and the stuff that I'm looking at can also be used as a sealer. I'm woundering if you can just lay the sealer down over the old scuffed paint or does there need to be a couple coats of primer underneith it first?
Here's the stuff, it's at the top of the list.
http://www.tcpglobal.com/kustomshop/ksppgprime.aspx
Old Nov 21, 2009 | 09:10 AM
prelude1897's Avatar
Default Re: Epoxy Primer/Sealer?
you don't have to spray primer on the whole car if you're repainting it. All you need to do is scuff the clear coat, cause the base coat will act as your primer. If you did some body work, then you should spray a few coats of primer over that.
Old Nov 21, 2009 | 11:00 AM
gorillafart's Avatar
also you really only need epoxy primer if you've reached areas of bare metal... if theres no bare metal.. use a high fill primer/primer surfacer.. and go from there
Old Nov 21, 2009 | 11:45 AM
Thanks for the info guys, I am going down to bare metal the the back quarters because I need to weld in fresh metal to fix the cancer, thats why I wanted to go epoxy, I have heard lots of good things. My plan was to buy a gallon of that, use it as primer on the bare metal, then mix it up and seal the entire car, wetsand if needed then lay down the colour.
Old Nov 26, 2009 | 09:38 PM
Anyone else order anything from TCP, "Kustom Shop?"
Old Nov 26, 2009 | 11:34 PM
RedneckRicer's Avatar
Epoxy Coat and Slick sand would be perfect if your taking it down to bare metal will make life much easier
Acidcrakker
Paint and Body
Mar 5, 2009 03:35 PM
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
Mfoehrkolb
Paint and Body
24
Sep 21, 2007 06:18 PM
turbotime
Jun 8, 2004 09:45 PM
GroundZer0
Sep 9, 2003 07:57 AM
