Koni Question
I forget what a EM1 is but:
if it's 95-95 Civic you need ITR rear LCAs and the fronts will work fine.
if it's 96-00 Civic I know the front is a little different. I think either the shock diameter is different or the fork width is different or both. And for the rear I think CTR rear LCAs would do it as the LCAs are shorter than the older Civic.
yes em1= 99-00 si, and no rear itr koni's will not fit, itr lca's are to long to fit on the em1, and ek9 ctr lca's are the same style as em1 si lca's
you will need to get civic rear shocks
sinatra
Aug 3, 2004 12:30 PM
Nerv2g
30
Oct 24, 2003 01:09 PM
EL-Driver
Aug 17, 2002 05:51 PM
