piston to valve cyn3
Old Nov 20, 2009 | 11:10 PM
93_hatch's Avatar
Default piston to valve cyn3
so was installing BC 3plus cams in my b16, had cam gear set at 0,0 and rotated the motor, on exhaust stroke the valve is hitting the piston, only on cyn 3. very confused its just stage one cams. only thought is to removed the head and see whats up? looking see what other insight can be shed on the issue.
thanks
Old Nov 21, 2009 | 10:38 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: piston to valve cyn3
make sure everything is lining up timing mark wise, I'd say it's off at couple to few teeth. Start over with everything at TDC and check your marks.
Old Nov 21, 2009 | 10:52 AM
93_hatch's Avatar
i will try that again the marks seemed good.
Old Nov 21, 2009 | 05:04 PM
93_hatch's Avatar
could the head be milled that much, to where a stage one would hit? any one know the height so i can check.
Old Nov 21, 2009 | 05:27 PM
Garrett's Avatar
with vtec engage or not?
Old Nov 21, 2009 | 09:37 PM
00Red_SiR's Avatar
All Motor Mentor
you should not be hitting the pistons with valves when you're using BC3 cams set at 0/0. IF you're SURE that everything is lined up and you're still hitting the pistons, something else is WAY off.
Old Nov 21, 2009 | 11:36 PM
q16racer's Avatar
he hasnt said what he has done to the bottom end so how do you really know?
________
Buy Silver Surfer Vaporizer
Old Nov 23, 2009 | 02:31 AM
00Red_SiR's Avatar
All Motor Mentor
I know by what I said. IF everything is lined up and he's still hitting the pistons, SOMETHING ELSE IS WAY OFF. (Read bottom end)
Dave_Dc2
Nov 27, 2008 07:42 AM
ChaseIntegra
May 27, 2005 02:36 PM
Mr. Samurai
14
Jul 3, 2004 03:47 PM
BlueTeg
Jan 25, 2004 04:01 PM
